Hey I was wondering if these wheels would fit (probably gonna need spacers).
Old Feb 22, 2006 | 08:11 PM
ZZ4 86 Z28's Avatar
Car: 1986 Z28 Camaro Gunmetal Gray with
Engine: GM Crate ZZZ HO 350, Edelbrock head
Transmission: Rebuilt 700r4 all TransGo and Beast
Axle/Gears: 10 bolt with 3.73 gears
I found a set of wheels and tires that i like and i was wondering how well they would fit on my car. im pretty sure they would be fine with a small (maybe 1/4 or 1/2 inch spacer). anyhow here are the wheel and tire sizes. i will not buy them if they will stick out in the slightest bit. "17x7 fronts with 4" backspacing with 215/40/zr17 Kumho ECSTA Supra tires. 17x9.5 rears with 6" backspacing with 275/40/r17 BF Goodrich G-Force T/A Drag Radials." i think the fronts would fit fine since theyre not that wide, and then im worried about a little too much backspacing on the rear wheel. if i throw a 1/4 or 1/2 inch spacer on there will it stick out? the reason i think it wont is because i know roh makes wheels for third gens that are 9.5 inches with enough backspacing to not stick out and not rub. thanks a lot for the help guys. i hope these can work.
Old Feb 22, 2006 | 08:13 PM
ZZ4 86 Z28's Avatar
oh yea, and if it helps, im running a 275/60/15 right now without any problems.
Old Feb 23, 2006 | 02:32 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
My wheels have 5" backspace front & rear. The front inner rim hit the tie rod. I used a 1.5" spacer & it's fine. 5" on back is real close, 6" would hit for sure.
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
TMoNeE
Northern California
Aug 24, 2015 06:11 PM
greeny
Wheels and Tires
Aug 12, 2015 03:55 PM
matthew911
Aug 12, 2015 09:38 AM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
