Adjustable Panhard Rod
Old Mar 13, 2006 | 03:02 PM
david roush's Avatar
Car: 92'Camaro RS
Engine: a loud one
Transmission: bolted to the engine
Unfortunatly the button isn't working here yet. What's the general rule of thumb or any guidelines on adjusting these ,if there is any?
Old Mar 13, 2006 | 04:29 PM
blyth18md's Avatar
Car: 82z28
Engine: 406
Transmission: th350
drop a line from the middle of the fender flare straight down mesure from tire to the line.
Ideally you want the same distance each side.
...unfortunately this wont work under all circumstances due to shotty factory tolerances and the unknown history of the car.
You could you a variety of other reference points though.
Measure with the car on the ground, but you probably wont be able to adjust it unless lifted....Its pretty common sense
Old Mar 13, 2006 | 04:32 PM
Souseless's Avatar
Car: 89 WS6
Axle/Gears: 10 bolt T2R w/ 3:23
start with the length on the stock one and you will be pretty close. Tune from there.
Hotrodboba400
Dec 10, 2019 07:07 PM
Antips16
Oct 30, 2015 06:42 PM
Nervous2
Oct 8, 2015 10:53 PM
TOMcat GTA
Sep 15, 2015 09:31 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
