Where to get a new torque arm bracket?
Old Mar 14, 2006 | 09:29 AM
PyRo9862's Avatar
Car: 91RS
Engine: 305tbi
I'm doing the 700r4 - t5 swap and basically everything is done except for one snag I hit. Whoever removed my t5 took a sawzall to the torque arm bracket and cut it in half.
Anyone know where I can get a new torque arm bracket or some aftermarket option that would work? I was thinking of cutting the one off the 700r4 in half and welding them together making a good bracket is that a bad idea?
Old Mar 14, 2006 | 07:53 PM
Jade Grey's Avatar
Car: 1992 Pontiac GTA
Engine: 305TPI
Axle/Gears: 10-bolt, 2.73
The bracket for the torque arm is different between manual and automatic transmissions. So, basically chopping the old 700R4 bracket in half is not that bad since you do not need it.
The bracket should be a pretty easy junkyard find. Otherwise, the two halves of the bracket are should still be dealer-stocked. Try a GM#10024028 and #10024025. The associateed bolts are different too.
Old Mar 19, 2006 | 06:39 PM
w1964bgta's Avatar
Car: 89 gta ws6, Dodge Turbo Diesel, H-D
Engine: 383 4-bolt #638 block
Transmission: 700r4, corvette servo, 2200 stall
Axle/Gears: 3.27 9 bolt b-w, pbr discs
torque arm bracket
Just do a parts wanted now post in the parts wanted section of our site.
Good luck!!
WickedBowtie
Members Camaros
Sep 17, 2015 09:13 AM
Ragtop Man
Sep 12, 2015 12:23 AM
WickedBowtie
Sep 11, 2015 11:24 PM
Nick McCardle
Sep 10, 2015 08:36 PM
