Have build sheet or invoice? Post shipping weight.
Old Mar 20, 2006 | 11:35 PM
blyth18md's Avatar
Car: 82z28
Engine: 406
Transmission: th350
Here is the list of cars I have so far, if any of these cars are yours feel free to notify me and I will add your engine/trans combo. And if you have the front to rear breakdown.
1982 camaro z28 (LG4/200c).......3296 (front 1945 [59.0%], rear 1351)
1982 pontiac S/E (LG4/4sp).........3041 (front 1978 [65.0%], rear 1063)
1983 camaro z28 (LG4/700r4)......3241 (front 1931 [59.6%], rear 1310)
1984 pontiac firebird (LG4/700R4).3230 (front 1938 [60.0%], rear 1292)
1986 camaro z28 (LB9/700R4)......3403
1986 pontiac firebird (LB8/T5)......3002
1987 camaro RS (LB8/700r4)........3106 (front 1722 [55.4%], rear 1384)
1987 camaro iroc (L98/700r4)......3478 (front 2064 [59.3%], rear 1414)
1987 camaro iroc (L98/700r4)......3461 (front 2064 [59.6%], rear 1397)
1987 pontiac firebird (LG4/700r4)..3635
1987 pontiac T/A (LB9/700r4)......3759
1988 camaro RS (LO3/700r4).......3285
1988 camaro SC (L03/700R4).......3249
1989 camaro iroc (LB9/700r4)......3250 (front 1930 [59.4%],rear 1320)
1989 pontiac gta.......................3389
1989 pontiac gta (LB9/T5)...........3363
1990 camaro RS (LO3/700r4).......3267
1991 camaro RS (LO3/700r4).......3305
1991 camaro z28 (L98/700r4)......3413
1991 camaro vert (LO3/700r4).....3425
1991 pontiac T/A (LB9/T5)..........3325
1991 pontiac T/A Vert (LB9/t5)....3455 (front 1996 [57.7%], rear 1459)
1991 pontiac firebird (LH0/700r4)..3117
1992 pontiac gta (LB9/700r4).......3419 (front 1993[58.3%], rear 1426)
1992 pontiac T/A (LB9/700r4).......3396 (front 1975[58.2%], rear 1421)
Here are examples of where to find the information on your build sheet and invoice. Add the numbers together (on build sheet) and you have the shipping weight.
Old Mar 20, 2006 | 11:42 PM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
1986 pontiac firebird 2.8L v6 3002
Old Mar 20, 2006 | 11:47 PM
blyth18md's Avatar
Car: 82z28
Engine: 406
Transmission: th350
thats with the t5 right?
Old Mar 21, 2006 | 04:53 AM
Brisk's Avatar
Car: '88 IROC-Z / '91 Z28 / '91 GTA
Engine: LT4 Hot Cam 305 / L98 355 / MR 383
Transmission: 5-spd / 700R4 / 700R4
Axle/Gears: 3:45 / 3:23 / 3:23
is there a build sheet hidden anywhere in the vehicles themselves? it would be great if I could find one in either of my two iroc's
Old Mar 21, 2006 | 09:45 AM
blyth18md's Avatar
Car: 82z28
Engine: 406
Transmission: th350
brisk, my build sheet was under my drivers side rear seat(actually I think there were 2 build sheets in my car, i forget where i found the second), but ive heard of them under seats and on top of the gas tank.
EDIT: I believe the second one was under the dash pad
Old Mar 21, 2006 | 10:01 AM
Trans It's Avatar
1991 Pontiac Firebird Trans Am convertible: F 1996 + R 1459 = 3455 lbs.
Old Mar 21, 2006 | 10:13 AM
blyth18md's Avatar
Car: 82z28
Engine: 406
Transmission: th350
LB9 correct?
Old Mar 21, 2006 | 10:27 AM
railroad's Avatar
1987 Camaro RS V6 2.8/700r4
3106 total 1722/1384 (55.4%/44.6%) stock form
engine code is LB8
Trans It's Avatar
Originally Posted by blyth18md
LB9 correct?
Yes, LB9 engine and M39 manual trans.
Old Mar 21, 2006 | 12:49 PM
phess11's Avatar
Car: 83 Z28
Engine: 305 (LG4)
Transmission: THM700R4
Axle/Gears: 10 bolt, 3.23 non-LS
here is mine.
1983 Z28 700R4 Ship Wt F 1931 + R 1310 = 3241
Old Mar 21, 2006 | 12:52 PM
blyth18md's Avatar
Car: 82z28
Engine: 406
Transmission: th350
Originally Posted by phess11
here is mine.
I dont think that worked.
Old Mar 21, 2006 | 02:15 PM
beady's Avatar
Car: 1990 Camaro
Transmission: 4L60
1990
1990 Camaro weight = 3267 Trans 4L60E
Old Mar 21, 2006 | 02:18 PM
blyth18md's Avatar
Car: 82z28
Engine: 406
Transmission: th350
thanks. and added
Old Mar 21, 2006 | 02:37 PM
conlinj's Avatar
1986 Camaro Z28 LB9/700R4 Shipping weight 3403, I need to get the documents for my s/c, I'll post when I get them.
-Jim
Old Mar 21, 2006 | 02:40 PM
blyth18md's Avatar
Car: 82z28
Engine: 406
Transmission: th350
-Jim
thanks and added.
Old Mar 21, 2006 | 03:29 PM
Brisk's Avatar
thanks blyth18md.. looks like I'll have to check ontop of my gas tank. I've had all my seats out along with the dashpad and didn't find anything before.
Old Mar 21, 2006 | 04:40 PM
91Zman's Avatar
Car: 1991 Z28
Transmission: 4L60 automatic
1991 Z28 L98 4L60 SW 3413
Old Mar 21, 2006 | 05:12 PM
blyth18md's Avatar
Car: 82z28
Engine: 406
Transmission: th350
thank you, and added
Old Mar 21, 2006 | 05:18 PM
Orinackra's Avatar
Car: 06 SRM M6 GTO, 98 Grand Prix GTP
sw: 3117
91 Firebird, 3.1/700r4
Old Mar 21, 2006 | 05:19 PM
91Zman's Avatar
Car: 1991 Z28
The tranny is a 4L60,renamed in '90 from 700r4.
Old Mar 21, 2006 | 05:40 PM
blyth18md's Avatar
Car: 82z28
Engine: 406
Transmission: th350
Originally Posted by Mitch DoGG
sw: 3117
thanks and added
Understood. Same tranny, new designation. Im going to leave it as 700r4 for the simplicity factor.
Old Mar 21, 2006 | 07:10 PM
phess11's Avatar
Car: 83 Z28
Engine: 305 (LG4)
I edited it.
Old Mar 21, 2006 | 07:29 PM
blyth18md's Avatar
Car: 82z28
Engine: 406
Transmission: th350
I edited it.
thanks for the correction and added.
Old Mar 21, 2006 | 10:32 PM
hwcoll95's Avatar
Car: 1989 Iroc rebuild
Engine: 355 carb'd
Transmission: 5spd
Axle/Gears: 3:08 pos for a while
found under passenger seat
in my 1989 IROC
but not much information
I don't have this information on my 1992 Z/28 either just RPOs
both are LB9 with 5speed cars
Old Mar 21, 2006 | 11:06 PM
Jade Grey's Avatar
Car: 1992 Pontiac GTA
Engine: 305TPI
Axle/Gears: 10-bolt, 2.73
The build sheet for my 1992 GTA (LB9, 700R4, T-tops, J42 rear) shows 1993# Front and 1426# Rear.
blyth18md, is the second sheet shown in your original post called a build sheet also? I have a sheet like the first one and then I have a sheet like hwcoll95 posted too.
Old Mar 22, 2006 | 01:33 AM
87TAairlineyard's Avatar
Car: 1987 Pontiac Trans Am
Engine: 305 LB9 Tuned Port Injection
Transmission: 700-R4 Automatic
Axle/Gears: Saginaw 10 bolt 2.73 posi
1987 Trans Am with LB9, 700R4, T-tops, most power options: 3759 lbs.
Old Mar 22, 2006 | 07:33 AM
phess11's Avatar
Car: 83 Z28
Engine: 305 (LG4)
1982 pontiac S/E (LG4/4sp)........3041 (front 1978 [65.0%], rear 1063)
1983 camaro z28 (LG4/700r4).....3241 (front 1931 [59.6%], rear 1310)
How did the 82 S/E save 247 pounds in the rear over my 83 Z28????? I don't have rear wiper or lugguage cover or anything extra. Did they put helium in the tires.
Old Mar 22, 2006 | 08:08 AM
black_highway's Avatar
Car: 91' RS Camaro
Engine: 305c.d. Toilet Bowl Injection
My 1991 RS = Shipping Weight 3305.
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Axle/Gears: 3.73 S60
My iroc when it had a 5 speed in it was 3250 (1930 front / 1320 rear) - 89 IROC 350 hard top, manual window, power locks, ac blah blah blah.
Dunno what it is now with leather gta seats and a auto.
Old Mar 22, 2006 | 09:48 AM
blyth18md's Avatar
Car: 82z28
Engine: 406
Transmission: th350
I guess build sheet style/layout could have changed over the years, or was different plant to plant? Or maybe what he posted was just a sheet for a certain section/ stage in the production line? Just a few possibilities.
Whats your engine code for this car?
Is this weight via the build sheet? Because you say 350, but then you said "when it was a 5 speed".
Old Mar 22, 2006 | 10:33 AM
Trans It's Avatar
A tad off topic, but that build sheet of hwcoll95's looks like one of the Dead Sea Scrolls.
Old Mar 22, 2006 | 11:33 AM
LetsRock's Avatar
Car: 1989 Trans Am GTA
Engine: LB9 TPI with L98 cam (Manual car)
Transmission: T5 5Speed/ 9bolt Borg-Warner 3.45 gears with posi
1989 GTA LB9 5speed. ship weight = 3363 lbs
Old Mar 22, 2006 | 11:41 AM
hot69z's Avatar
Car: 1982 Z/28 H.O.
Engine: 355
Transmission: t-5
OK I did some number adding and subtracting using the weight i had for my car after i did my fiberglass pannels and other weight saving tools and I came up with 2982. I have a 1982 Z/28 with a 71chevelle 350 4 bolt main and a 84 T-5. The car has the factory fiberglass hood as well as fiberglass fenders and decklid, I have yet to do my doors, there is also no padding under the carpet or on the firewall. and aluminum heads im sure make a weight difference also. the closest I could figure is the front end being significantly lighter because of the fenders and heads alone, as for where the weight transfer of the carpet insulation would fall who knows. The problem with that number is I do not know how much heavier the high nickle block 350 is or how much lighter the aluminum heads and intake would be. Dead stock my car would of been 3296 because it was the LG4/200c combo as you have listed. I don't know if this is what your looking for at all but I figured I would post anyway....
Old Mar 22, 2006 | 11:43 AM
blyth18md's Avatar
Car: 82z28
Engine: 406
Transmission: th350
Just looking for offical ship weights myself. But the information you provided may be helpful to someone else and its greatly appreciated.
Old Mar 22, 2006 | 09:06 PM
Car: 91' RS Camaro
My engine code is LO3.
Old Mar 22, 2006 | 11:18 PM
Guest
Guest
Posts: n/a
84 Firebird LG4/700R4
1938/1292
Old Mar 23, 2006 | 06:09 PM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
F and I never said the car was stock That was the actual weight of the car.
Orignally it was a 305 auto car. When I got it, it was half assed 5 speed swap (the guy had the bright idea to put all the mechanical linkage stuff in it. Awesome cause I set the clutch where I wanted, but pita to keep up since it was hobbled together) Then when I blew up the second T5 and clutch, I went to a T56.. Blew the clutch up in, replaced that rebuilt the trans, then had two bearings nuke themself cause I forgot to put a plastic spacer in there. Fixed that, then blew the clutch again. So now it is a auto. lol
Fuxx manuals. lol
Old Mar 23, 2006 | 08:12 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Has anyone found the build sheets in a '92? I've had the front seats out, the rear seats out, the upper rear carpet out, the drivers side door panel out, and have yet to find anything. It is a Canadian built car, did they put the build sheets in them?
RBob.
Old Mar 23, 2006 | 08:38 PM
robertfrank's Avatar
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
1988 lo3 when it was bone stock was 3285
Old Mar 25, 2006 | 09:47 PM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
RBob.
Found mine behind the pass door panel.
Old Apr 8, 2006 | 11:11 PM
cs2000's Avatar
I found the build sheets for my '89 and '91 inside the cars when I test drove them, I took them out before the prep people cleaned the car for delivery. My '87 Convertible built at Norwood I bought used and never found the build sheet in it. and I had the whole interior out of it. Chris
Old May 1, 2006 | 09:27 PM
  #42
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
i have one from an 88 s/e with 2.8 and 700r4 somewhere when i find it ill post the weight or scan it and show it
Old May 6, 2006 | 07:48 AM
  #43
V8Rumble's Avatar
Car: '89 Trans Am GTA
Engine: WAS 350 - now L92 (alum. 378/6.2L)
Transmission: WAS 700R4, now a built T56
Axle/Gears: 3.27 9-bolt
Not entirely sure how accurate this scale was, but I drove to a place that sold landscaping rock (weighed the customers' vehicles before & after loading), & got an actual weight there. With my (roughly) 200 lb. carcass in the car, it came in at 3750.
(And I've been shaving weight off the car ever since!)
Old Jun 11, 2006 | 03:47 PM
  #44
blyth18md's Avatar
Car: 82z28
Engine: 406
Transmission: th350
TTT
Old Jun 13, 2006 | 02:59 PM
  #45
koolbreeze92's Avatar
Car: 1992 Brilliant Red Metallic with T-
Engine: LB9 305 TPI
Transmission: MD8 4 Speed Automatic
Axle/Gears: 2.73....Paint peeler
1992 Trans Am w/ t-tops
Found build sheet in back cubby hole. All options except rear disc brakes, assembled Van Nuys, California. 305 tpi (LB9) 4 spd auto(MD8) 2.73 rearend(GU2) Positraction(G80)GAWR F (2143)GAWR R (2064)SHIPPING WT. F (1975)SHIPPING WT. R (1421)Hope this helps some. Later
Old Nov 18, 2006 | 08:45 AM
  #46
DarthD's Avatar
Car: 2001 Trans Am WS6
I thought I would revive this to see if there are any more.
Old Nov 18, 2006 | 06:53 PM
  #47
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I was looking for this thread a couple of weeks ago and couldn't find it
Got it bookmarked now
Old Nov 18, 2006 | 08:18 PM
  #48
di11avou's Avatar
Car: 1988 Camaro
Engine: 305ci TBI
'88 Camaro SC: Hardtop, L03, 700R4, A/C, Manual locks and windows
SW: 3249
Old Dec 2, 2006 | 12:47 PM
  #49
DarthD's Avatar
Are all fluids installed except fuel for shipping? It seems there must be something else that is not in the car during shipping because the weights do not match up. The shipping weight plus the weight of a full tank of fuel do not quite add up to the curb weight of the car.
Old Dec 3, 2006 | 08:20 PM
  #50
1986Z28OWNER's Avatar
Car: 1979 Malibu
Engine: Blown LSx
Transmission: T56 Magnum
Axle/Gears: 9"/wavetrac/35's/3.70
86' Z-28 LG4 700R4
