where to get new WS6 springs
Old Apr 2, 2006 | 05:37 PM
88GTAbandit's Avatar
Car: 1988 pontiac Trans Am GTA
Engine: DFI,Single Plane,200cc Dart I.E,355
Transmission: Th400 PTC converter
Axle/Gears: Stock Ausie 9 bolt w/3.45 gears
hey guys, i was going to replace my WS6 springs, and have no clue were to get a new set from...the car goes to the track alot and street races....i also drivethe car during the summer to shows and every weekend.......its your typical street strip car.....but i have no clue were to get them....also what backspacing should i get for the Pro Stars that i am getting? they are 15x8 rear and 15X3.5 or 15x4 (165 50/60r 15) for the front...going to run either 275 60r 15 mickey DR's or 275 50r 15 DR's...and to make sure, the bolt pattern is 5x4.5 or 5x4.75.....My car is an 88 GTA L98 w/ausie borg warner3.45 and 4 wheel disc
thanx for any help
dave
Old Apr 2, 2006 | 09:17 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
you buy stock style springs where you buy any stock type of parts, part zone, pep boys (i'm not sure what you guys have in the states, all are named different up here, but your basic parts store is what you want)
you can check on the moog website, and check what spring # is used for your car, then check with a year newer, older, etc. Then search and find the spring rates for those springs.
ie, the 5662 is probably what you'll end up buying for the fronts. the 5660 is slightly more tame. the 5664 is only for S15 trucks really, but it fits the same, and is even stiffer.
rears you have the choice of cc635 (variable rate, aka "cargo coil"), or.... I forget the straight rate style part #, but I bought cc635's for mine. The parts store should be able to look them up, just tell them your car, and say the heavy duty suspension one.
Old Apr 3, 2006 | 12:15 PM
Forshock 85TA's Avatar
Car: 85 Trans Am
Engine: 350 (CCC QJet)
Axle/Gears: 3.08 9 bolt
rears 5665
Ed1LE
Sep 30, 2018 09:14 AM
jrdturbo
Mar 31, 2016 02:58 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
