Alston SFC's and Spohn Torqe Arm
Old May 2, 2006 | 09:29 PM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
Will the Alston SFC's fit with a Spohn Torque Arm? Looks like there's an interference problem with the front of the bars and the trans mount. Just wondering if anyone's tried it since I don't have a set of the SFC's here to mock up.
Old May 8, 2006 | 03:27 PM
Brian Shaughnessy's Avatar
Car: '89 Formula
Engine: 355 TPI
Axle/Gears: 3.70 9 bolt.
Mounted mine a long time ago now... Had to get the hack saw out and cut a little on the crossmember to clear the Alstons on the Formula.
Old May 9, 2006 | 07:24 AM
Anniversary-Z-man's Avatar
Car: 1992 25th Anniversary Z28
Engine: 6.3L - 383
Transmission: 700R4; Vig 3200
I've got both the Alstons and Spohn TA and there's minimal interference to worry about...worst case is you grind a little off where the SFC is welded to the frame near the TA mount....nothing to worry about.
- Joel
no green
Jan 9, 2016 09:22 PM
darwinprice
17
Oct 11, 2015 11:51 PM
LT1Formula
Oct 8, 2015 08:34 PM
loud91rs
Oct 5, 2015 10:05 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
