Replacing steering wheel & column on 1990 Z28, what fits?
Old May 11, 2006 | 06:15 AM
McGuireV10's Avatar
The subject says it all -- I have a couple sources for various used steering wheels and columns of various years ranging from 1989 through about 2000. What will work in a 1990 5.7L IROC Z28 with VATS?
(I'm not opposed to disabling VATS, the car has a pretty excellent aftermarket alarm.)
Thanks!
Old May 14, 2006 | 09:55 AM
Z's r Best's Avatar
Car: '86 IROC, black and sharp
Engine: 305 tpi, bone stock
Axle/Gears: 3.42 pos w/rear db
Had to replace the column on my son's 91 RS (key switch and column busted up). It had/has VATS as well. We used a tilt steering column from an 88 Forumula (direct bolt in) and reprogrammed the chip to ignore VATS. Also, the RS is a 5 speed and the Formula was an automatic. The wirgin connectors were different. We had to remove the wires from the column connectors and then put the Formula column wires into the RS column connector so all the steering column switches (wipers, dimmer switch, turn signal, etc.) worked. Try autozone.com for wiring diagrams. Put a Grant GT steering wheel on it so he wouldn't have an RS that said Pontiac on the horn button.
Frozer!!!
Jan 19, 2024 04:55 PM
Jorlain
Aug 24, 2022 05:11 PM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
mustangman65_79
Aug 9, 2015 03:00 AM
johanlindgren
Wheels and Tires
Aug 6, 2015 03:32 PM
