15" rims w/rear disc brakes
Old May 11, 2006 | 07:09 PM
raptor80dad's Avatar
Car: 92rs
Transmission: 350
Axle/Gears: 3.73/Moser 12bolt
I read the sticky on measurements and not too sure I have it right .has anyone put 15" rims on a iroc w/ rear disc brakes?if so do you have the measurements?please excuse my ignorance.
Old May 11, 2006 | 07:10 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
15" rims were available with all stock rear brake systems.
Old May 11, 2006 | 07:22 PM
Car: 92rs
Transmission: 350
thanks.the calipers were my fear.i am sure i can measure backspace and offset.
Old May 11, 2006 | 07:31 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
That's stock rims though... clearance on aftermarket rims may vary, but it shouldn't be a problem.
Old May 14, 2006 | 09:45 AM
Z's r Best's Avatar
Car: '86 IROC, black and sharp
Engine: 305 tpi, bone stock
Axle/Gears: 3.42 pos w/rear db
I've got a set of 83 Z28 (stock) 15" rims on my red IROC (stock disc brake rear end) right now. Doesn't seem to be any clearance issues.
Old May 14, 2006 | 12:08 PM
IROCZZ3's Avatar
Car: 87 Buick GN
Engine: 3.8L (231 cid) V6
Transmission: 200-4R
Axle/Gears: 10 bolt G80/ 3.42
If trying to use non-OEM wheels....15" Draglites will not clear PBR calipers from a 9 bolt unless you grind down the fins on the back of the caliper.
Old May 14, 2006 | 01:57 PM
1989GTABlown632's Avatar
Car: 1989 Pontiac Firebird Trans-Am GTA
Engine: Blown 632 CID with Nitrous
Transmission: TH400
Axle/Gears: 4:10
i had same problem, I had 15x8 draglite XPs that rubbed, i used a 1/4 spacer to clear the caliper.
Hotrodboba400
Dec 10, 2019 07:07 PM
fasteddi
Sep 10, 2015 09:32 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
Night rider327
Sep 2, 2015 04:18 AM
