Wheel Spacers
Old May 18, 2006 | 04:26 PM
cc 82Z-28's Avatar
Car: 82 Z-28
Engine: Built 406ci
Transmission: 700R4 w/3000 stall
Axle/Gears: 3.73 Torsen Posi, Moser Axles
Wheel Spacers
Well, I ran into a problem with converting my car over to C-5 brakes, I put 17" rims on, but, I have a back space problem. The rims are 0mm backspace which is for the car, but with the new rims that are almost 13" in diameter the caliper hits rim. Looks like I need a 1/2" or just alittle smaller to make it work. Any suggestions on where to get them? Thanks..
Old May 18, 2006 | 06:25 PM
cc 82Z-28's Avatar
Car: 82 Z-28
Engine: Built 406ci
I found the spacers needed from ezaccessory.com. They are 1/2" thick aluminum with the bolt pattern of 4 1/2"-5".
Old May 24, 2006 | 04:41 PM
Z's r Best's Avatar
Car: '86 IROC, black and sharp
Engine: 305 tpi, bone stock
Axle/Gears: 3.42 pos w/rear db
Don't know how long your wheel studs are but I'd think about getting/installing longer ones if you're going to put a 1/2" spacer between the wheel and the drum/rotor. If you don't you won't have much stud in the lugnuts.
JB82Z-28
Exterior Parts Wanted
Oct 6, 2015 09:05 AM
xXIROC ZXx
Wheels and Tires
Sep 15, 2015 11:18 PM
Fionnla
Wheels and Tires
Sep 11, 2015 11:07 PM
punkmaster98
Sep 8, 2015 09:45 PM
turbobuick88
Wheels and Tires
Sep 8, 2015 08:27 PM
