215/65/15 to 235/60/15, balanced twice, still shakes
Old Jun 21, 2006 | 06:20 PM
coolrimsatleast's Avatar
Car: 89 f-bird and some others
Engine: 3.4
I recently went to 235/60/15 from the 215/65/15's. They're BFgoodrich radial TA's. I had some shaking in the steering wheel anywhere from 45 - 60mph and had them re-balance the tires. I still have a little shaking though around 48-51. It seems worse on the shoulderless county roads where there's more of a slant in the pavement to steer against. Everywhere else I barely notice it, and that's still only when applying slight pressure on the wheel to keep it straight in a few spots.
Are there any issues with going to this size with a stock V6 suspension and no re-alignment? I had the alignment done only a month ago, and the ball-joints etc. where checked too and still tight. (although they probably need a lube job)
Or should I explain to the place what's happening and have them try again.
My 2 front center-cap things are loose now too for some reason, but I don't think it's affecting everything else. (the lugnuts are tight)
Old Jun 21, 2006 | 06:38 PM
di11avou's Avatar
Car: 1988 Camaro
Engine: 305ci TBI
Are they static balancing or dynamic balancing the wheels? Any bent rims?
Old Jun 21, 2006 | 09:57 PM
92zcamaroperson's Avatar
Car: 92 z28 25th
Engine: 5.7 liter
Transmission: 700-R4
like he said bent wheel maybe. Check to make sure that you bearings are nice and snug. jack the car up and take hold of the tire and try to wiggle the wheels. Push the front side in and the rear side of the tire out. Then back and forth.
92firebirdguy
Sep 1, 2016 07:53 AM
92-Formula
Dec 12, 2015 10:34 PM
TheCardinal
Exterior Parts for Sale
Oct 1, 2015 07:40 PM
monte87cortez
Sep 26, 2015 08:10 PM
Magman
Sep 13, 2015 12:14 AM
