hub or wheel spacer?
Old Jun 28, 2006 | 06:11 PM
Bifferd's Avatar
I know I'm not calling it what it is because I know what hub spacers are and I dont need one.
My camaro has 2.8 diameter in the hub, my new rims fit the bolt pattern but the hub is 3.62 in diameter. So I need a spacer that wll go on my hub so the rim fits snug on my car so all the weight isnt on my lug nuts.
Cant find them anywhere tried alot of parts stores dont get far calling them hub or wheel spacers either, the bolt pattern works so I dont need a hub spacer.
know where I can find 4 or what they are really called.
Old Jun 29, 2006 | 07:38 AM
BMmonteSS's Avatar
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
Some wheels are hub centric, and others are lug centric. All this means is that either the hub or the studs center the wheel. The actuall weight of the car is taken up by the lugs and the friction between the wheel and hub face. Don't worry about the hub not touching lots of GM cars left the factory that way.
Old Jun 29, 2006 | 10:46 AM
DRR's Avatar
DRR
Car: Nothing stock- I screw with everyth
Engine: Hook&Ladder #8
Transmission: Morris Code
Axle/Gears: AxleROse CD Collection & Scuba Gear
I agree with Bmonte's statement. But if you still want to go that route the things you need to search for are called "hubcentric rings". You'll need to find one with a 3.06" ID and the 3.62" OD your new rims have.
JB82Z-28
Exterior Parts Wanted
Oct 6, 2015 09:05 AM
xXIROC ZXx
Wheels and Tires
Sep 15, 2015 11:18 PM
Fionnla
Wheels and Tires
Sep 11, 2015 11:07 PM
punkmaster98
Sep 8, 2015 09:45 PM
turbobuick88
Wheels and Tires
Sep 8, 2015 08:27 PM
