Poly Bushings PLEASE HELP!
Old Jul 26, 2006 | 06:05 PM
kurupt209's Avatar
Car: 86' Iroc-Z
Engine: 305 tpi
Axle/Gears: 2.77s
hi i have a 1986 IROC its got the 305 tpi 700r4 and the open differental with the 2.73s and well to get to the point my endlinks to the sway bay are broken completely in half on one side and i just need to know what size is my sway bar its all stock im gonna buy the whole kit from summit poly bushings with endlinks so someone please help me out.
Old Jul 26, 2006 | 06:12 PM
ScottyRS's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
All the endlinks are the same size. Aren't they?
And here's a thread with a bunch of bushings sizes. Check your RPO codes and measure the bushings yourself just to be sure.
https://www.thirdgen.org/forums/faq-...y+bar+size+f41
By the way, if you need to drive the car you can remove the sway bar entirely. Just be careful around those corners.
Old Jul 26, 2006 | 06:17 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Sway Bar bushings you'll have to order - you'll need to measure the diameters of the front and rear sway bars. Poly end links can often be found on the shelf at Autozone or Advance - end links are the same size front and back. If the other old one won't come apart with a wrench, cut it with a hack saw right through the rubber above and below the sleeve, and take the pieces out - they tend to rust inside the sleeves, amking it impossible to get off - to avoid this next time, try a can of anti-seize and "paint" the bolts before installing the sleeves.
Ed1LE
Sep 30, 2018 09:14 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Nervous2
Oct 8, 2015 10:53 PM
loud91rs
Oct 5, 2015 10:05 PM
mfp189
Sep 27, 2015 09:25 AM
