Tricks/tips or recommendation for idler arm level?
Old Aug 1, 2006 | 07:24 AM
crazynights's Avatar
Car: 1982 Z-28
Engine: 383
Transmission: Turbo 350
Axle/Gears: Det. Posi, Superior Axles, 3:73 G
I'm putting in a new Idler arm and centerlink since they've been in since 82. When I removed the idler arm I noticed alot of play on the centerlink.
Anyway, in the Chiltons they recomment when replacing the idler arm to measure it with a socket and some other tool to make sure it's level with the pitman arm off the steering box, (hope I said that correctly)
I was wondering if I could just use a level and just make sure it's level that way. Has anyone else done this or can advise me of any tips?? Thank you.
Old Aug 1, 2006 | 10:10 PM
SDIF's Avatar
Car: 91 Z/28, 89 RS Race Car
Engine: 305 stock / ZZ4 AFR 195 9.7:1
Transmission: T5 / t10 / Jerico
Axle/Gears: 10blt w 3.42, 9 in w /3.80 DL
You need to set a benchmark.
Get a long level and measure the frame rails. I would pull the front sway bar and place the level on the mounting points. This will give you a good point to measure from and you can get a level in there. Use a jack to manipulate the the car until the level reads level. Turn it 180 degrees and measue again.
You have now set benchmark.
Keep the chassis where it is and move level to the idler arm and pitman arm. Adjust idler arm until the level reads level.
Of course keep the arms pointed as if the car wre going in a strait line when measured. They will swing in an arc and will upset your measurement.
Old Aug 2, 2006 | 06:43 AM
Car: 1982 Z-28
Engine: 383
SDIF,
Thank you very much!! I'll give this a shot and let you know how it works. I know the old idler arm was set incorrectly cause the arm's bolts were all the way up top in the adjustment and the centerlink was crooked. Thank you again, I'll repost my success when I get this done.
Old Sep 16, 2006 | 01:22 PM
Trans Am#5's Avatar
Car: 1987 Trans Am
Engine: Lt1
Did this work for you?
Old Sep 19, 2006 | 11:57 AM
Car: 1982 Z-28
Engine: 383
It sure did. Worked like a charm. My old one was way off and when I put this new Idler arm on with this method, the steering felt much more responsive. Also the car always felt to turn right easier and this fixed that problem.
no green
Jan 9, 2016 09:22 PM
LT1Formula
Oct 8, 2015 08:34 PM
loud91rs
Oct 5, 2015 10:05 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
mfp189
Sep 27, 2015 09:25 AM
