Tires
Car: 1986 Iroc z z28
Engine: 305 tpi
Tires
well i need new tires. i am running 245/50z/r16 right now and i want the widest tire i can get on the stock iroc 16's any suggestions??
Car: 87 TA
I've got 16x8's with a 50 series tires. you could prolly go up to a 60 but you might have a bit of clearance issues in the front and they'd be pretty low. I like to keep the wheel well filled in.
the widest 16" made is 255, so you get a whole 10mm wider than factory.... - 60 series would be taller, but not wider, and unless you're geared short enough taller tires will hurt performance.
- They do make wider in some specialty race tires, but then you'll need a wider wheel for them to fit.
Engine: 305 tpi
i have 2.92 or 2.72 out back i belive what ever come stock there another question i just wanted to know what a good tire to get cuz mine are bald
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
