need help with suspension
Old Aug 9, 2006 | 05:05 AM
cfosceola's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
so i replaced my struts about a month ago and this past weekend i replaced the ball joints springs and endlinks, and then had an alignment. after a couple of days the struts are now making a grunt type noise, and my car sits like 2 inches higher than before.
1. could the struts be bad since i didnt change it out at the sametime.
2. when i changed the springs i matched them up and they were the same height, old vs new
Old Aug 9, 2006 | 06:11 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Did you index the front springs? Springs have a different rate. (You may have chosen badly.) Your old springs may be been in such sad shape that the new ones actually put the car at stock height.
JamesC
Old Aug 10, 2006 | 09:45 AM
cfosceola's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
well i figured out what happened, i jacked up the front of the car and noticed that the spring was rubbing on the side where it goes up into, so i slid up the spring compressor and compressed it and then used a pry bar to slide the spring into place and it just popped back in, lifted up the arm and then released the compressor. i guess when i did it the first time i released the compressor first so it just sat in there wrong. now there is no noise at all coming from the strut and the car sits perfectly,
LT1Formula
Oct 8, 2015 08:34 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
