Idler arm bush
Car: Camaro & 75 C20 Dually
Engine: 2.8 V6 & 6.2 V8 diesel
Transmission: manual & auto
Axle/Gears: ??????
Idler arm bush
Hi all
I'm new here:-)
I have an 87 Camaro 2.8 V6. It had a lot of play in the idler arm bush. I went and had a look today. When i wiped all the grease and gunk off it i saw it had a big hex on the bottom. I wondered if i could unfasten this and replace the bush. I tried to undo the hex but t only turned a few turns and locked up solid. Since i did this it has no play in the idler bush. Are these idlers adjustable? I've looked at a lot of photo's on the net and i haven't seen any other idlers with this big hex on the bottom.
I haver only had the car a couple of months now and only just got it running, it's a big difference from my 75 C20 Dually pick up truck:-)
Thanks in advance
I'm new here:-)
Thanks in advance
Idler arm is not generally a serviceable part on these cars. You just replace the whole thing. Only costs about $35 on this side of the pond.
Is your car right-hand drive, or left-hand?
Axle/Gears: ??????
I know they are not usually adjustable but i have never seen an idler like this one before. It has a big hex at the base like a nut. Parts are not very cheap in the UK over double what you pay for them so we usually try and fix things before we buy new:-) I've been looking at online parts store and all the pictures are different to the idler i have? It's a left hand drive:-)
no green
Jan 9, 2016 09:22 PM
LT1Formula
Oct 8, 2015 08:34 PM
