widest tires i can run
Old Oct 1, 2006 | 11:17 AM
Fbody891's Avatar
Car: 91 firebird
Engine: 305 TBI
Transmission: 5 speed
what are the widest tires i can run with my stock 15's? i have 215/60/15 and i just want a wider tire. i was also wondering if i have a wide tire in front will it effect steering/cornering
Old Oct 1, 2006 | 04:32 PM
Zedsled's Avatar
Car: 84 Z28
Engine: Modded 350ci.
I ran a 265/50/15 on the back of my 85 for about 3 years...I didnt have any problems with rubbing.The car handled pretty good(a little different to get used to in the rain)
On the front i was running a 225/50/15. thats about as big as i could get on the rim before i had tire rub in the fenderwell.
You will notice a difference in handling and how the car drives down the road.Here in ottawa some of our roads are pretty rutted and the car would tend to wander around in the ruts(no where nere as bad as my 84 with 275 or 255 on the front does) But in terms of performance driving(cornering and such) the wider tires with a shorter sidewall will add to performance. The shorter sidewall allows for less deflection in the tire so it will flex around less.
Old Oct 1, 2006 | 06:06 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
235/60/R15 is the same height as the stock tire. I have those in the front, no problems. It drags the plastic tire well insert sometimes, I think it's due to it being a 2nd gen wheel with a different offset.
275/60/R15's outback here. Others have done 275/60 on a 15x7" wheel as well, it's THE answer.
Old Oct 1, 2006 | 06:29 PM
dave-92gta's Avatar
Car: 92 trans am/ 93 dodge spirit V6
Engine: L98 V8 - 350
Transmission: TH-700-R4
im running 245/50/16 all around, no problems, in fact im going to lower one inch to fill in gap
Old Oct 1, 2006 | 07:26 PM
Fbody891's Avatar
Car: 91 firebird
Engine: 305 TBI
does how wide you rim effect how wide of a tire you can put on it? thats one thing im worried about is if it will leak air because the bead wont fit right or something like that sorry if im questions seem a lil dumb but i know knwothing about this
does yokohoma make a good tire?
Old Oct 1, 2006 | 11:58 PM
sully91rs's Avatar
Car: 91 RS, 95 Z28
Engine: 305 tbi, 350 lt1
Transmission: 4l60, 4l60e
Axle/Gears: monsterous 2.73s in both
I also have 255 on 15x7s in the rear. 255 is the max tire width listed on tirerack.com for a 7 inch rim.
BTW, the look awesome and I get compliments all the time.
EDIT: My brain hiccupped, I have 255s, not 275s. They still look nice.
Old Oct 4, 2006 | 11:12 PM
GuitarJunki17's Avatar
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
255/60/15 rears and 235/60/15 fronts.
Gives the car a nicer stance, rather than the whole front looking like it is a little higher than the rear, stance (on a stock suspension anyhow).
Thats the only combo I would run on my 15x7s
Old Oct 7, 2006 | 12:47 PM
ling427ttvette's Avatar
Car: 1983 Camaro Z28/1999 Cavalier
Currently I have a 215/60R15 on the front, and 245/60R15 on the back. Personally I wouldn't go wider than that on a 15x7 rim because the tire is barely bulging out on the sidewall, anything wider wouldn't look right.
Yes, the width of the rim WILL determine the widest tire you can run on there. It would be hard as hell to put a 295/50/15 on a 7" wide rim, and it would be stupid to.
I will be upgrading to 245/45R17 in the very near future. I could go wider on the back, probably like a 265/45, but I don't really need it.
The best reason for getting wider tires, is better traction. Now, it would be complete over kill if you had a 2.8 V6 in there, and stuck some 10" wide rims on the back with some 305's on there or something. Only go as wide as you need to, don't just go wide for looks. Function over form.
Old Oct 8, 2006 | 07:43 PM
sully91rs's Avatar
Car: 91 RS, 95 Z28
If I was to go by the function over form rule, I'd still have 215s all around.
I went 235 front, 255 front for better traction, but also because I like wide tires on sports cars. Although I agree with ling about going 10" wide rims with a 2.8L to be overkill.
Old Oct 8, 2006 | 08:22 PM
Fbody891's Avatar
Car: 91 firebird
Engine: 305 TBI
i have 225s right now so im guessing 240 250 will work for me thanks everyone
Old Oct 9, 2006 | 09:58 PM
xtransxamx's Avatar
You can fit a 275 tire on a 15x8 with proper backspacing, and a little fender roll.
Old Oct 10, 2006 | 11:11 PM
sully91rs's Avatar
Car: 91 RS, 95 Z28
Its a 15 x 7.
Old Oct 12, 2006 | 10:23 PM
txcamaro's Avatar
Car: '86 Camaro Z-28
Engine: 305 V8
Transmission: 5-Speed standard
I've got 255/60s all the way around. Fills the fenderwells nicely. I have a little fender rub on the front, but I only notice it when I'm trying to make very tight turns into a parking spot or something like that. Corners a heck of a lot better than the 195/70 14s that were on the car when I bought it. I'd recommend the 255 or even the 245/60.
Old Oct 15, 2006 | 08:45 PM
MotorCityRS's Avatar
Car: 90' Camaro RS
Engine: 3.1
Transmission: 4l60
I'm about to put 275/60/15 on my rs. 255 in the fornt. Those t/a's sure will look good.
eightsixseven
Dec 16, 2024 01:50 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
fonzie85
Exterior Parts for Sale
39
Mar 16, 2016 07:07 AM
demontransam89
Wheels and Tires
Dec 28, 2015 06:58 AM
