Loaded or Unloaded?
Old Oct 27, 2006 | 02:59 PM
BADMAN's Avatar
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
Axle/Gears: 3.55 Wavetrac
Loaded or Unloaded?
Am currently rebuilding a 1985 Iroc front end. I understand that on any suspension rebuild(front or rear) you always tighten the components with the suspension loaded.( Wheels on ground). I was just wondering if you did not do that and tighten everything up with the wheels in the air would it harm anything? Don't worry, I did'nt make this mistake, I'm just curious. Badman
Old Oct 27, 2006 | 03:13 PM
kaptinkafeen's Avatar
If you tightened up the suspension without it being loaded by the weight of the car - when you did/do lower the car the suspension would bind. A good example would be the lower A-arms - if you tightened up the lower bolts prior 'loading up the suspension', when you drop the car down onto its own weight, the A-arms would bind not allowing free or smooth suspension travel. Similar situation with LCA etc...
-Andrew
Old Oct 27, 2006 | 03:33 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
It's different for different components. I usually tighten it in the air though... If I can i'll jack the car up and keep the suspension loaded (don't jack by the frame rails). But if it's a shock or something you're replacing, that won't work.
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
Rocket-Doc
Nov 14, 2015 02:08 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
skinny z
Oct 5, 2015 06:23 PM
efiguy
Sep 27, 2015 01:30 PM
