Eliminate P/S
Eliminate P/S
What would I need to do to eliminate the power steering from a 1991 Z Camaro? I don't want there to be slack or play after the pump is removed. How can I make it tight and responsive w/o the pump?
If I did keep the p/s, which pulley system set-up would you recommend? All I need is waterpump, power steering & alternator. Please provide part numbers because I will be ordering soon. Thanks
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
To eliminate your power steering, remove pump, hoses, brackets etc. Remove power steering box, remove pitman arm from power steering box. Install manual steering box from 84+ S10. Install third gen pitman arm onto manual box. Done.
Do a search. Some people have minor clearance issues with the manual box. You also may not like the manual steering box. It's 7 turns stop to stop so parking lot driving becomes difficult especially if you have a smaller steering wheel. The extra turns are required to increase the mechanical advantage since there's no power assist.
You want the S10 box with the 4 bolt top cover. The earlier 3 bolt top covers will work but the pitman arm shaft is smaller so you can't use the third gen's pitman arm. It's a slightly different length than the S10's.
Okay, i got ya. Now what about a pulley system with a power steering pump? I am using an older carbed sbc engine in a '91 z, but my buddy DOES want to keep the p/s. can you tell me which pulley set up to get (waterpump, alternator, p/s)
Car: 87 IROC L98
I don't use power steering or a SBC. My engine has 2 pulleys. One on the crank, one on the alternator using a 6 rib serpentine belt.
Pick something you like. There's lots of choices available. Converting to a serpentine belt is far better than the old V-belts. Serpentine doesn't mean you need a reverse direction water pump.
Pac J
May 17, 2020 10:44 AM
