suspension hela stiff?
Old Nov 5, 2006 | 09:59 PM
Orizon's Avatar
Car: 1984 Trans Am
Engine: BuiLt 350! Hooker 2055's
Transmission: T5-manual trans-centerforce clutch
just replaced my shocks/struts and springs, kyb gr2, some napa oem replacment springs. also redid my whole steering: idler arm, tie rods, centerlink etc. i havent taken it for alignment yet but i drove it around the block just to see if it would settle n what not. the front seems crazy stiff. if i push on the fender it berely goes down at all. the only thing i can think is if i overtightened the control arm pivot points? is this possibly the casue and if so, how tight should they be? thanks in advance,
Old Nov 6, 2006 | 10:20 AM
CrazyHawaiian's Avatar
Car: too many ...
When you put it back together did you torque everything with the suspension loaded? Its very possible stuff is overtightened and/or binding. I don't remember the torque numbers off-hand, any good manual will have em. If you don't have a hard copy of any manual Autozone has online manuals with the torque specs for each bolt.
Old Nov 6, 2006 | 05:00 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I think it feels nice and tight like a sports car again. What's the problem?
Old Nov 6, 2006 | 06:43 PM
Orizon's Avatar
Car: 1984 Trans Am
yes i torqued it with the car on the ground. and yes perhaps theres not a problem i just figured the front should drop a little if i sit on the fender, but perhaps the front is supposed to be a lot more stiff then the rear? seems maybe thats the case..... but again ima recheck the control arm pivot bolts incase.
Old Nov 6, 2006 | 07:06 PM
CrazyBear's Avatar
Car: 1987 Camaro,'89 firebird
Engine: 305 quadjet, 305 tbi
Axle/Gears: 2.73. 3.2xs
yeah the front is stiffer than the rear because of the engine and other components way a lot compared to carpet and some accessories.
Old Nov 6, 2006 | 08:03 PM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
I dont think a person under 120lbs could move my car by pushing down
thats the way you want it
Old Nov 6, 2006 | 09:27 PM
Orizon's Avatar
Car: 1984 Trans Am
yea, i drove it over to get an alignment and it seemed fine, i guess i just wasnt used to it being stiff like it should be.
LT1Formula
Oct 8, 2015 08:34 PM
gord327
Sep 29, 2015 10:18 PM
