springs
Old Nov 14, 2006 | 10:20 AM
monoply6's Avatar
Car: 89 trans am gta
Engine: 5.7
Transmission: auto
Axle/Gears: 9 bolt
springs
hi all need so imput on where to get a set of spring for my gta ive got a new set of kyb gr2 shocks i dont want to lower my car but would like a firmer ride any help on this would be appreciated thanks
Old Nov 14, 2006 | 11:44 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Moog replacement springs can be bought at O'Reillys if there's one near you or ordered through Summit Racing (other sites probably as well). You can go to the Federal Mogul site and look up the replacement springs for your car and they'll provide spring rates and installed heights, allowing you to compare different parts #s. Spohn's site lists a set of replacement Moog "IROC" style springs also but doesn't provide the part numbers.
I replaced the springs on my TA this weekend with Moogs from O'Reillys and it raised it up about an inch from the sagging 20+ year old springs. Rides much firmer and more comfortable but I still need an alignment before I get too crazy with it. Swapped the front control arm bushings out with Moog replacements too for around $180 for 2 sets of bushings and 4 springs.
Old Nov 14, 2006 | 12:00 PM
monoply6's Avatar
Engine: 5.7
Transmission: auto
Axle/Gears: 9 bolt
hi thanks going to check them sights now
LT1Formula
Oct 8, 2015 08:34 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
