tire sizes
Car: 1989 RS Camaro
Engine: 350 Carb(soon a 400)
Transmission: 5-Speed/th350
Axle/Gears: 10 bolt 3.73
tire sizes
ok I am running iroc rims and 265 50 16's. I have them all the way around. Yes they rub like crazy on the frnt. my question is what size tire should I put on the front so they will not rub but I iwll still have the same "stance" of the car. I don't want to put a smaller tire so the front end drops. I was looking for a tire size decoder(?) but could not find one. thanks
Car: 1987 Iroc Z28
Engine: 350 HSR
Axle/Gears: 3.27 Borg Warner 9bolt
Your car should take 245/50/16 I would put that size on the front and they will not rub The first # is for width 245 The second # is height 50 Hope that helps
Car: 1984 Trans Am
cpullma2 is close with his description of tire numbers. 265 - 50 means the crosssection (width) of the tire is 265 mm when properly inflated on a proper width rim. The 50 means the height of the tire is 50% of the width dimension when properly inflated on a proper width rim. They are just guidelines and actual tire sizes vary from brand to brand.
Hotrodboba400
Dec 10, 2019 07:07 PM
TheTraut88
Sep 7, 2015 05:22 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
