Is there really any difference?
Old Dec 15, 2006 | 03:27 PM
Ryan_Alswede's Avatar
Car: 1992 Camaro RS & 1992 Camaro RS
Engine: 3.1 L v6 & 305 (5.0L) v8
Transmission: 4L60 Auto
Tire sizes. Ever sense I've had my Camaro I've always had 215 - 60 sized tires on her. I'm told that stock was 215 - 65.
Is there a difference in handling or ride between the two?
Old Dec 15, 2006 | 10:21 PM
di11avou's Avatar
Car: 1988 Camaro
Engine: 305ci TBI
The 215/60s would probably handle a bit better with their shorter sidewall. They'll also make your car ride about a 1/2in lower. The drawbacks are the ride might be a little more harsh (probably not much though) and your speedometer will be off slightly.
If you want to switch to a tire that won't throw off your speedo and don't want the 215/65s, a popular choice is the 225/60/15. It's the same height as the 215/65, but it's 1/4in-1/2in wider.
Old Dec 16, 2006 | 07:39 AM
215/60 is too small. They'll wear faster than they should, and are otherwise a downgrade for the car in every way. I'm surprised a tire store would actually sell those for that application.
Next time you get tires, get 235/60. Much better fit and match. That's the size that's ACTUALLY the right "+0" option for one of these cars. 225/60 (Mustang) is still too small of a tire.
Old Dec 16, 2006 | 10:49 PM
di11avou's Avatar
Car: 1988 Camaro
Engine: 305ci TBI
Thanks Sofa. I started thinking later that it was actually 235.
69GTOby
Apr 18, 2016 02:34 PM
BAMiller
Sep 14, 2015 06:38 PM
Numbah-1
Sep 12, 2015 08:57 PM
J.C. Denton
Sep 8, 2015 05:35 PM
greenyone
Sep 2, 2015 03:39 PM
