max. tire size
Old Dec 20, 2006 | 03:53 PM
91thirdgen's Avatar
max. tire size
i was wondering what the maximum tire and rim size i could fit on an 86 iroc z without moving the springs in
also with the springs moved in but with out tubing
Old Dec 20, 2006 | 04:52 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
good luck moving the springs i think its impossible
Old Dec 20, 2006 | 05:06 PM
Blackroc86's Avatar
Car: 1986 Iroc
Engine: 454 Demon 850DP
Transmission: TH350, 3500 stall
Don't think you will gain any room inside without tubbing. You can pound the inner wheel well flatter but that is about it.
Old Dec 22, 2006 | 06:14 AM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Kandied ran 18"x8" front and 18"x10" rear with 245/40x18 and 285/35x18.
Old Dec 22, 2006 | 05:30 PM
matt_p's Avatar
Car: 1991 Z28
Transmission: WC T5
Axle/Gears: 3.73 Posi
My 295's just squeeze in. They tuck in from the fender lip and they have about 1/2" of clearance from the inner fender well. They rub the well though in hard turns because of the sloppy rubber bushings in the pan hard bar. Poly will be going in soon.
Here's a picture.
Some people put in 315's, but you'll either have to clearance the wheel well or have the wheels stick out. Which looks kinda silly. Member on this forum have done both
Old Dec 24, 2006 | 03:48 PM
A10Beav's Avatar
Engine: LS2
Axle/Gears: Moser Ford-9, 3.50
Here's a picture.
I currently have 275's but I've been looking to add 295's; looks like a good fit. How bad is the noise with the KDW-2's you're running?
Old Dec 24, 2006 | 06:35 PM
DragRadialRacer's Avatar
Car: 2005 Chevy Duramax, 83 Z-28
Engine: 408 SBC with Edlebrock Vic Jr Heads
Transmission: T350
Axle/Gears: custom 8.5, 4.56, spool, SSM
I have a 295/65-15 MT Drag Radial on my 3rd gen. Not sure if that is the route you were going.
Hotrodboba400
Dec 10, 2019 07:07 PM
SG91camaro
Sep 5, 2015 10:27 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
