15x8 of 15x10 drag wheels
Old Jan 4, 2007 | 02:35 AM
Igor's Avatar
Engine: 383 carbed sb
Transmission: th350
Hey guys,
Who makes a 15x8 or 15x10 light drag wheel (and what offset) to fit a third gen.
I want to run 28" tall slicks, and if I can get away with 15x8s I don't see why not.
Here is the thing.
I also have a 4th gen and plan on running my third gen 9" diff in this car. I'm assuming a set of third gen wheels would then fit the back end of the 95 with a third gen style diff. THis is kind of why i'd like to keep it as narrow as possible for some margain.
Anyone have any clue if this could/will work?
Thanks a lot,
Igor.
Old Jan 4, 2007 | 05:10 PM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
4.5" bs on a 8" and 5.5" bs on a 10".....although 5.5" might be pushing it a bit with a 28" tall tire. Lots of companies make drag lite rims.....Centerline, American Racing are the big two.
Old Jan 4, 2007 | 05:13 PM
Igor's Avatar
Transmission: th350
So you think 8" wide with 28" tall would work well?
Old Jan 4, 2007 | 06:34 PM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
The tire height does'nt care about rim width, the tire WIDTH does. Running a wide tire on a narrow rim really buldges out the sidewall and cups the foot print unless you really air them down.
I run the 10" rims with 5.5" BS and 28x11.5 Hoosier quick time pro DOT slicks, I have 4 buddies running that same tire on their 8" rims. Tire profile is alot more straight up and down on my 10" vs their 8" rims....but both do work. Base your rim size on the width of the tire you want to run-wider tires want/need wider rims so sidewalls can perform like they're supposed to.
Here's what mine look like with the 28x11.5x15 on a 10" rim and 5.5" BS mounted to my Moser 9" rear end:
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
buckshot63
Sep 10, 2015 09:15 AM
punkmaster98
Sep 8, 2015 09:45 PM
turbobuick88
Wheels and Tires
Sep 8, 2015 08:27 PM
