What size spacers? [19x10 79mm offset]
Old Jan 11, 2007 | 05:37 PM
ihnsane's Avatar
Car: 1989 Chevrolet Camaro IROC-Z
Transmission: A4
I tried to figure it out with the info from this thread...
and I think I just confused myself even more.
What size spacers would I need to put 19x10" rims with a 79mm offset onto my 89 iroc?
[REAR ONLY]
&& would I have clearance issues? [at stock height]
Thanks much, I appreciate it.
ihnsane
Old Jan 11, 2007 | 06:37 PM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
What is the backspace?
Old Jan 11, 2007 | 07:29 PM
ihnsane's Avatar
Transmission: A4
I don't actually have the rims so I can't measure them, but I searched and I found some information on a few sites.
The Skulte site says the backspacing on C6 19x10 rims is 8.11", and they recommend 2.25" adapters.
Some other site that are selling 2006 C6 Rims say the backspacing is 8.60"
Which one sounds right?
Old Jan 11, 2007 | 08:49 PM
ihnsane's Avatar
Transmission: A4
Well, I bought them regardless. When I receive them I'll get the true backspacing.
If it's going to end up costing me too much, I'll just resell them.
I got them dirt cheap anyway.....here is a pic, what do you think?
flawless
Old Jan 12, 2007 | 04:49 AM
Car: 89 IROC
With a stock brake set up I would not go more than a 6" back space. So you would probably need spacers. You could increase to 6.75" but it might rub and then you would have to do a bit of inner fender massaging with a hammer. Keep in mind the rim and tire height combined should not exceed 26.1".
Old Sep 5, 2007 | 07:54 PM
jstoltz's Avatar
Car: 1987 Iroc-z Convertible
Re: What size spacers? [19x10 79mm offset]
did you ever get these put on? what size spacers did it take and was there any clearence problems?
Old Sep 6, 2007 | 12:09 AM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
I'm running this combo with a 4thgen rear + 1" spacer and the tire sits flush with the fender. Doesn't rub with a 295/35-19 which is a 27" tire.
Old Sep 6, 2007 | 11:36 AM
jstoltz's Avatar
are you running the 18x8.5's (oem) up front? what size spacers are you using there and is yours lowered?
Old Sep 7, 2007 | 08:45 PM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
It's lowered 2.25" in the rear and at least 2.5" in the front.
It's the oem 18x8.5 with a 275 tire and a 2" spacer left over from the wagon wheels. If I bought spacers for these specifically I'd use a 2.25"
Old Apr 18, 2014 | 07:53 PM
durrettcustoms's Avatar
Realize this is 7 years old but what springs did you lower your car with?
Old Apr 18, 2014 | 10:48 PM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
I started on eibach sportlines with some cutoff. Exactly how much I cannot remember, 1/3 coil? 1/4 coil? 1/2? Been too long. Now I'm on weight jacks.
Nervous2
Oct 8, 2015 10:53 PM
the_hamturdler
Exterior Parts for Sale
Sep 21, 2015 08:55 AM
xXIROC ZXx
Wheels and Tires
Sep 15, 2015 11:18 PM
rb85TA
26
Sep 14, 2015 10:29 PM
turbobuick88
Wheels and Tires
Sep 8, 2015 08:27 PM
