Indexing front springs..where to put them?
Old Jan 13, 2007 | 04:19 PM
Wishmaster's87IROC's Avatar
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
Ok I have my front springs out and I need to put them back in....I know about indexing them...I know they cover the holes...but do they cover just one hole or both? and if they only cover one hole how far past the hole do I go? do I put them in the middle of both ...I have also heard halfway cover the second hole....
which is the correct way?
Old Jan 13, 2007 | 09:29 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
You should only cover 1/2- 1 hole the other leave empty.
Old Jan 13, 2007 | 10:17 PM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
I put the end of my spring half way between the holes. I think as long as you can look up through the holes and have one hole fully covered and the other hole fully uncovered you are fine.
Old Jan 14, 2007 | 10:14 AM
Exactly. With the end in between the 2 little holes.
No greater precision is required, or beneficial. The rust and dirt built up on the old parts, and the paint on the new, produce greater errors and tolerances than whether the spring half covers one hole or whatever.
Remember: measure with micrometer, mark with chalk, cut with axe.
There's places where finesse and careful attention to precision and detail, will pay off; this isn't one of them.
1992 Trans Am
May 10, 2023 07:19 PM
MustangBeater20
Oct 29, 2022 09:20 PM
customblackbird
Aug 15, 2021 10:16 PM
CRFred
Feb 7, 2016 11:39 PM
Greg '85 T/A
Aug 14, 2015 01:40 PM
