3 in lowering kit?
Old Feb 2, 2007 | 06:39 PM
Elusivewhite's Avatar
Car: 89 Firebird
Engine: little one
Transmission: 5-speed
3 in lowering kit?
so i have a 89 firebird that is a daily driver/project car. My rear shocks are just not cutting it anymore and the ride is really rough so i think i want to work on suspension next. I want to lower it 3 in instead of just fixing it stock but i have no idea where to start in looking for parts. I want to do it the right way instead of heating/cutting springs but i dont know where to look for the right parts so any info is helpful, thanks.
Old Feb 2, 2007 | 07:14 PM
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
i see you are a newbie here.. 1 post.. well anyway, have you really thought about how low a 3" drop is on a 3rd gen?? assuming you have, and have thought out all the consequenses of going that low i would say buy any drop spring kit and hack a coil or 2 off.. there are alot of banners on this site for aftermarket parts.. for example, look up top, there will be a banner for something.. well back to the topic, i would use the SEARCH button and look into drop kits and pros and cons of doing it.. i really dont think you have any clue what you are getting into with a 3" drop.. so do some research and then see if you really want all 3".. sorry to come off as an a$$.. but try to at least do a small search before you ask something like a 3" drop.. it will save us from having to write things twice.. and after a while of people asking the same questions(not necessarily your question) it gets annoying.. and again, sorry for breaking it to you like this.. happy searching..
Old Feb 2, 2007 | 07:40 PM
92purplehaze's Avatar
Car: 90 IROC-Z
Engine: Lsa
Transmission: M6
Axle/Gears: 9" spooled 3.70
I agree on both points first before you ask a question search it and youll probably end up with more information than if you started a new thread. Also you DONT want a 3" drop only if you were to bag it or dont plan on driving it
Old Feb 2, 2007 | 07:47 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
Mine is dropped about 3", it is very low. there are not "lowering springs" that will do that, I am running a ground-control weight jack setup. be prepared though, you will not really be able to get into any driveway's without draging parts of the car.
Old Feb 5, 2007 | 02:08 AM
86irocterror's Avatar
mines is at least 3 inch drop in the front and am changing it. my air dam drug while driving, not scrape, drug, i have about 1/8 inch from the top of my tires to my wheel wells. CANT drive it. lucky for me it hasnt been drivin for about 6 years now. i put about 5 miles on it to switch it from my old garage to the new one and couldnt with the front that low. sportline springs are nice, but when i put spohn a arms on it dropped like a bitch. so now im doing coil overs soon. anything more then 2 inch and you will destroy your car
Old Feb 12, 2007 | 07:38 AM
XxGeinNothingxX's Avatar
Car: 1991 Camaro RS
Engine: 350 bored .30 over
Axle/Gears: Posi 342
Ya, I was gunna say; our third gens are already low enough. Mine is stock and I scrape everywhere, and can't park in a lot of driveways. Think of the consequences before you do this, and like everyone said, do a search on pros and cons. I myself would jsut fix it back to stock, I also need to do this, my ride is a bit rough in the rear end, but it might be becuase of the subs, I dunno.
Old Feb 12, 2007 | 08:07 PM
DillonRager's Avatar
do you got a pic i never seen a third gen witha 3" drop thats nuts
Old Feb 12, 2007 | 08:29 PM
1989formula355's Avatar
Car: 89 formula, 89 Cadillac Brougham
Engine: 355,HSR,patriot alum. heads,TFS cam
Transmission: 700r4, 2500 B&M stall, shift kit
Axle/Gears: 3.73 ten bolt, powertrax locker
i used intrax 2" springs in my 89 formula, and the measured drop was 1-1/2" in the front and only about 3/4" in the rear. and that's about as low as i'm willing to go. air damn scrapes every where, where the exhaust passes under the oil pan is way too low, and i need to pick up on the front fender to get it on the lift. looks good though.
Old Feb 13, 2007 | 07:20 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Mine has a 1.75 drop on it. I would not go past that w/o making it adjustable. I can get in most driveways around here, but I can not go over speedbumps, pull onto shop racks, let alone get it towed if it quits on me.
I have to drive onto 2x4's to jack it up
Actually, its there enough stock tire clearence for 3"?
Old Feb 14, 2007 | 02:26 AM
vejatabul's Avatar
Car: 1988 gta
Engine: 5.7
Transmission: turbo 350
yes. i had my gta lowered roughly 3 inchs, and damned if it was a crappy ride. luckly, i pulled soooo much wieght out of the car, that it raised up about an inch and a half. never again would i do such a stupid thing...
now i have sphon coilovers, complete tubular suspension, and less ground clearance due to the exhaust. i still have not finished putting the car back together, but you can be sure i wont roll around that low anymore.
Old Feb 22, 2007 | 01:59 AM
dillonrager..... go to www.bigbrakeupgrade.com and go to customer feedback and look for the black camaro. it is only a front shot for the guy to post of the brake kit he did for me but you can see the drop there.
Old Feb 22, 2007 | 05:11 AM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
ElusiveWhite,
Eibach sportline would give a 1.5 - 2" drop. There are lots of pics of guys who have done this on the board. It looks good and the wheels look like they fillout the fender. A 3" drop would be a very hard ride and not really practical as some have ointed out.....good luck
Old Feb 22, 2007 | 06:57 AM
Dale's Avatar
Engine: 350 S-TPI
dillonrager..... go to www.bigbrakeupgrade.com and go to customer feedback and look for the black camaro. .
Thats so low, it looks like the suspension is broke
Old Feb 23, 2007 | 12:15 AM
it does doesnt it........lol it sat perfect when i put the sportlines on but then i later put spohn tubular a arms on and it dropped it about another inch or more....i have c5 brakes on so it moved my wheels out 1/3 inch and the top outside edge of the tire is at most 1/8th inch away from inner wheels wells!!!
Old Feb 24, 2007 | 04:24 AM
83 Crossfire TA's Avatar
It’s all relative… 3” from where a late RS with springs that have been sagging for 20years is a ton (hell, in that condition the car probably sits about the same as it would with a new set of sportlines), 3” from stock ride height of an early 80’s car (say before about 85, they sat at least 1-1.5” taller then a later car) is not so much.
My ’83 TA was lowered about that much (somewhere in between those 2 extremes), it was down far enough that the stock bump stops would touch the k-member at ride height. At first I trimmed them down, later I replaced them with shorter, poly bullet shaped stops. I think at it’s lowest point, with everything tucked up tight (custom exhaust…), it was around 2.5” off the ground even with fairly tall (235/60/15 and 255/60/15, roughly 26.1 and just over 27” tall tires, compared to the 25.5-25.7” tall that most people run).
My formula (with eibachs and normal height tires) looked like a 4x4 parked next to it, it was at least 1”, probably more taller.
I didn’t have any real problems with driveways, at least not more so then my ’97 WS6 does, actually it’s probably worse, but did have the occasional weird incident. I smashed 2 tranny pans going through the same fast (>60mph) dip in the road with some weak front struts (I’m sure it wouldn’t have happened otherwise), and my wife got stuck in a gas station when she hit one of the fill caps for the underground tanks. It was tough to drive in anything more than about 3-4” of snow because it would get packed under the K-member and the front tires would loose traction.
Come to think about it, I probably didn’t have any problems with driveways/speedbumps because I made a conscious effort to not have problems, as in I remember reading 4wheeling magazines about entry/exit angles to maximize clearance over big bumps..
I am considering swapping the same set of springs into my ’87 TA, but that will probably depend on what tires I end up running, but I’ve never been a big fan of short, low profile tires (I was happiest and fastest autoXing the ’83 on G60 hoosiers, which are about the same as 245/60/15’s) even though I do tend to like a low ride height.
One thing that I would suggest to anyone going that low… figure out your bump stop heights in the front without springs in it. There is a spot on the back of the control arm that comes close to hitting the frame/k-member, and there isn’t a lot of leeway WRT to shorter bump stops before you’re liable to end up with metal to metal contact (read, a bad, BAD thing) on the back of the control arm. Also, make sure that none of the frame/body contacts the ground with a flat tire, or it could make for an ugly situation if you have a blow out going down the road.
morrow
Jan 13, 2024 12:29 PM
BHR
Sep 3, 2015 07:51 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
Night rider327
Sep 2, 2015 04:18 AM
Night rider327
Sep 2, 2015 04:17 AM
