need help
Car: 02 Mustang
Engine: 3.8 about to be punched out to 4.3
Transmission: 4R70W
Axle/Gears: 3.73 Detroit true trac
need help
trying to read through the rim sticky about offsets and back spacing and i really dont understand it, can someone help me out? basically, i destroyed one of my front rims and was wondering if I could use teh rear one on the front since i have 2 snows for the back
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Yes I can help....what kind of rim do you have on the car? Are they stock or not? Rim size...15", 16". ............
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
You can look on the backs of the rims - if they are marked "frt" and "rear" then you'll have to have them on front and rear accordingly. With 16" Iroc rims, I'm assuming your answer would be no, they cannot be swapped front to rear - but look at the rims and see if they are marked.
