gta wheels, what's the difference from frt & rears
Old Mar 3, 2007 | 07:43 PM
gtatech's Avatar
what is the difference between front and rears.i just bought a 87 gta, i changed the tires and noticed that it had two rears on the rear and one rear on the front.i can't really tell the difference. should i expect any problems? the rears have the spacers.the car drives fine. HELP!!!!!!!!
Old Mar 3, 2007 | 09:18 PM
Mongoose's Avatar
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
There may be clearance issues with a rear wheel on the front. The backspacing is 0mm(around a 4" backspace)for the front wheels and +16mm(around a 4.75" backspace) for the rears which pulls the rears into the wheelwell. Check the one front wheel you have against one of the rears and you'll see what I'm talking about. This arrangement was designed into the WS6 suspension to help the handling but I haven't noticed any change in my Formula with the different wheel setups I've ran through the years. Most people try to find 4 fronts as they look better with the wider lip.
LilHot
South Central
Apr 13, 2026 11:46 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
kah992
Aug 19, 2015 02:55 PM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
