Good sub frame connectors?
Old Mar 5, 2007 | 04:37 PM
Tenom's Avatar
Car: 1989 GTA
Axle/Gears: 3.23s
Seems like a deal but most sites have subframes at like $170+
http://sfbay.craigslist.org/pen/pts/286255860.html
Old Mar 5, 2007 | 08:31 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
stay away. all they are, are pieces of straight tubing. you have to cut the floorpan and run the bars through it in order to connect the subframes
Old Mar 7, 2007 | 05:54 PM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
I agree with 86TA. It is a lot of work. Best to find something you can bolt or weld on direct. Look at UMI or Spohn. May cost a bit more that $ 60 but no hassles.
Old Mar 12, 2007 | 09:56 PM
carls1982z's Avatar
Car: 1982,Z/28
Engine: 355
Transmission: t350
So has anyone here use the ones topdown solution sells, they are different then most out there.---just bought some and hope they work out ok
Old Mar 16, 2007 | 07:04 PM
carls1982z's Avatar
Car: 1982,Z/28
Engine: 355
Transmission: t350
SO no one here used the sub frame conn that top down solution sells ????
Old Mar 16, 2007 | 07:14 PM
AmorgetRS's Avatar
Those are alston SFCs. Do a search and you'll find out lots of people are using them :-)
Ghettobird52
Jul 5, 2024 11:18 PM
Frozer!!!
Jan 19, 2024 04:55 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
LittleFranks
Aug 20, 2015 03:55 PM
Derick15
Members Camaros
Aug 20, 2015 10:19 AM
