going to change my rear shocks. need advise
Old Apr 10, 2007 | 04:04 PM
formula forever's Avatar
Car: 91 formula
Engine: 350 tuned port. bolt ons
This sunday Im going to change the rear shock on my car. I need some advise tips to make the job go smooth. I only read about changing them but never did a live job. I do have to suport the rear end on jackstands right? thank your help.
Old Apr 10, 2007 | 04:31 PM
craparo's Avatar
Re: going to change my rear shocks. need advise
dont know how i did do it but i remember that it was real easy there is 1 or 2 bolts up top that you have to pull back the carpet think i used the jack to lower the rear end dont know where i put the stands but a 1hr or 2 should do it!
Old Apr 10, 2007 | 04:43 PM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
I changed the rear springs last week in 30min with 2 hydraulic jackstands.
Yes if you lift the entire car on a lift you need a to support the rear end. It would be much faster leaving it on the floor and just lifting the rear untill you can unbolt the shocks and slide them out with the axle resting on the weels.
Also take only the right trackbar bolt out. And the upper 2 shock bolts are on the inside under the carpet. Hope that helps
customblackbird
Aug 15, 2021 10:16 PM
BlackTopKing
Aug 19, 2015 12:13 PM
jackhammer
Aug 15, 2015 10:04 PM
kyleb24
Aug 15, 2015 08:24 AM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
