Hope this isnt a dumb question?
Old Apr 22, 2007 | 08:31 PM
Dans87GTA's Avatar
Car: 1987 Pontiac Trans Am GTA
Engine: 355 Stealth Ram
Transmission: 700R4 w/ 2600 stall
Axle/Gears: 9-bolt 3.27
I was just wondering how long our the end links? And where is a good place to get a set of poly end links and sway bar bushings? i would rather get them locally but i dont know if any parts stores have them. mainly because some of the people working there dont know a u-joint from an air filter if the computer asking the wrong questions. Thanks for the help Later Daniel
Old Apr 22, 2007 | 09:53 PM
Z28 Boy's Avatar
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
Re: Hope this isnt a dumb question?
i would just look up the part number on summit or something like that. then stop at autozone to see if they've got them (assuming you have autozones in your area). they have a handful of energy suspension end link kits in stock - one may be what you're looking for.
brian
Old Apr 23, 2007 | 05:39 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
http://www.spohn.net/category.cfm?categoryid=1069
JamesC
Old Apr 23, 2007 | 09:22 AM
Dans87GTA's Avatar
Thanks! I saw that before but one thing i noticed i have an 87 and i have a 36mm front sway bar and that one say if your "1LE" needs a sway bar. i know 1LE didnt come out till 88 so how do i have a 36mm sway bar? i know i do because i measured it 3 times just to make sure. Thanks Daniel
Old Apr 26, 2007 | 04:11 PM
Shagwell's Avatar
Car: projects.......
Vatozone has the engergy suspension stuff in one of their isles. Usually right across from the euro tail lamps, led lights, and the 6" exhaust tips....
Old Apr 26, 2007 | 06:35 PM
MurcoRS's Avatar
Car: 1989 Camaro RS
Engine: ZZ4 350
Axle/Gears: BW 9-bolt w/3.73
LMAO!
Actually, AutoZone and Advance Auto both carry TRW end links with poly bushings under part# 18250HD, for about $11 each. Make sure you get the HD parts (red bushings).
Old Apr 27, 2007 | 11:45 AM
Shagwell's Avatar
Originally Posted by MurcoRS
LMAO!
which would be cheaper and probably as good as the energy ones...
formula1lle
Jan 29, 2016 10:56 AM
NinjaNife
Aug 23, 2015 11:49 AM
ezobens
Aug 19, 2015 10:29 PM
Bryan F
Aug 18, 2015 02:28 PM
redmaroz
Aug 16, 2015 11:40 PM
