Eibach Springs
Old May 16, 2007 | 07:24 PM
  #51
SteelTownMadDog's Avatar
Re: Eibach Springs
Originally Posted by Camaro5690
If you want vogtland springs, they are WAY cheaper HERE than at Hawks.
I emailed them a few days ago and they have the following PROGRESSIVE rates;
Front: 336-628 lbs/in <-that's sad actually
Rear: 183-228 lbs/in <-that's a nice rate for the back
Old May 17, 2007 | 06:16 AM
  #52
Camaro5690's Avatar
Car: 1985 Camaro/89 Merkur XR4Ti
Engine: 5.0 305 LG4/2.3 Turbo (180hp/205tq)
Transmission: TH700R4 with Shift Improver Kit/T-9
Axle/Gears: 3.42LT1 Rear/3.64
Re: Eibach Springs
looks like 5664s for the fron and vogtland for the rear then.
Old May 17, 2007 | 01:01 PM
  #53
3.1EyeCandy's Avatar
Car: 1987 GTA
Transmission: 4L60e
Re: Eibach Springs
I'm loving the theory in this thread. Thanks MonteSS!
Is there any thirdgenner out there who has the cut springs as Monte describes with a nice shock/strut (bilstein HD?) setup? Some personal experience would be nice here.
Old May 19, 2007 | 11:54 AM
  #54
hotpart's Avatar
Re: Eibach Springs
The 336 rate is only to preload the spring to give it enough free length to keep it from falling out of the spring pockets. The springs mostly work in the 628 range and only go to the 336 at full droop.
Old May 19, 2007 | 01:21 PM
  #55
Re: Eibach Springs
Either way, 628 is still to soft for any kind of decent handling fbody doing autocrossing.
LT1Formula
Oct 8, 2015 08:34 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
