Suspension help
Car: Firebid Cab-92/1989 TTA
Engine: 383 HSR TPI
Transmission: TH700r4
Axle/Gears: 4.10
Suspension help
Hi!
I have a way to soft suspension today and dont have a clue what to spend the money on,have about 600 usd to spend,what do you get for that.
Today it is a lowerd stock suspension i think,you dont whant drive it over 90mph today.Thanks for any replay.
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
Axle/Gears: 3.55 Wavetrac
Re: Suspension help
First step,sub-frame connectors. They stiffen up the chassis and are the baseline to start with. Then you need to see what condition your front and rear suspension are in.Check suspension forumn search for shock,lower control arms, bushings, and other upgrades. Also larger front and rear sway bars if your car does not have them. Again, use the search. Much info.Badman
Engine: 383 HSR TPI
Axle/Gears: 4.10
Re: Suspension help
Ok!
What about geting somethings from a jynkyard trans am whith ws6,will that fit my car,it is from the beginning a 305 tbi cab-92.
Thanks!
Thanks!
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
Re: Suspension help
If you get the WS6 sway bars, that would be a good upgrade. I have the WS6 bar on the front of my car, and I really like it.
Also, you will want to get some aftermarket shocks. Personally, I think a GOOD set of shocks will help more than replacing the springs and installing all the bars you can throw at it.
First thing to do, though, is like BADMAN said, get SFCs then check and replace the bushings and things in the front steering and suspesnion. The rears can be replaced with the aftermarket bars and stuff.
I hope that my lack of order in this post didn't mess you up, lol. It did me.
Engine: 383 HSR TPI
Axle/Gears: 4.10
Re: Suspension help
Ok thanks!
Will everything fit from a trans am to my firebird or are there some parts that dont bolt right on my car?
LT1Formula
Oct 8, 2015 08:34 PM
