Pitman arm of doom - help!
Old May 5, 2007 | 12:07 PM
dbrunner2's Avatar
Car: '89 Camaro RS
Engine: 1994 F-car LT1
Transmission: T5 World Class
Axle/Gears: Jag XJ6 IRS, 3.42, Auburn Pro posi
Tried to change my steering box today, and I can't get the pitman arm to budge, even though I put a pitman arm puller on it, torqued it until it deformed the end of the puller's shaft (a pretty good puller too, from Napa), and hit the end of the shaft about 20 times with a 15-lb sledge. It looks like it's rusted to the sector shaft. Does anyone know a way of getting it off and having it still be usable with the new steering box?
Old May 5, 2007 | 01:55 PM
Re: Pitman arm of doom - help!
Soak it real good with penetrating oil... NOT WD-40, but rather something that actually works for that, such as PB Blaster. Wait a day or 2. Add some more every now and then.
Do what you're doing about putting lots of pull force on it, and hit it. Instead of hitting the Pitman shaft, hit the arm in the "off" direction.
Incidentally, the "sector shaft" is the one the steering column bolts to, not the one you're working on.
Old May 5, 2007 | 02:18 PM
1989formula355's Avatar
Car: 89 formula, 89 Cadillac Brougham
Engine: 355,HSR,patriot alum. heads,TFS cam
Transmission: 700r4, 2500 B&M stall, shift kit
Axle/Gears: 3.73 ten bolt, powertrax locker
crank that puller on there, soak it with pb blaster, then hit the pitman arm like crazy with an air hammer (right around the shaft area) the vibration of the air hammer will work the pb blaster in and let it do it's job. that arm should pop right off after that.
Old May 5, 2007 | 02:39 PM
Stevo's Avatar
Car: Pair of 92 Z28s
Your changing the pitman arm to the new box? Im guessing cause it didnt have one on the new box? Or are you talking about where the pitman arm attaches to the drag link?
If so i had to use a torch to get it apart from the drag(center) link.
Old May 5, 2007 | 03:37 PM
dbrunner2's Avatar
Car: '89 Camaro RS
That's right, the new box didn't come with a pitman arm so I have to separate the old one and reuse it. I actually had no trouble separating the pitman arm from the center link when I changed the link some months ago.
If the arm doesn't come off when I try hitting it from above with a piece of bar stock and the sledge, would it be worth heating it with a torch?
Old May 5, 2007 | 06:29 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Sometimes you can struggle all you want with mechanical tools with no success. A little bit of heat may be all it needs.
Old May 6, 2007 | 08:52 AM
fire350tpi's Avatar
Car: 1988 Pontiac trans am/gta
Axle/Gears: 3.23's
/agree just like 02 sensors
no green
Jan 9, 2016 09:22 PM
LT1Formula
Oct 8, 2015 08:34 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
