better strut?
Old May 5, 2007 | 01:49 PM
joecautela's Avatar
better strut?
any thoughts on KYB-GR2 vs. Monroe sensatrac? I'm looking for a decent replacement for a stock suspension, thx, Joe
Old May 8, 2007 | 12:16 AM
Kandied91z's Avatar
Re: better strut?
go with which ever is cheaper.. i have not had luck with the 2 kyb sets i owned as they both went out after a month of driving. however for their defense i was running a lowerering spring and didn't have them paired properly. if your going to replace your springs with factory rate springs as well kyb's might be ok.
i wish bilsteins were cheaper... they are wonderful.
Old May 8, 2007 | 12:22 AM
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
Re: better strut?
for stock replacement, go with the sensatracs.. i had them and they were pretty good..
Old May 8, 2007 | 12:25 AM
Kandied91z's Avatar
Re: better strut?
even they are expensive for what you get but i would agree if you can find a decent price. i put them on my rs with moog springs and they rode great. not like the bilsteins but what could i expect for a $350 savings.
Old May 8, 2007 | 06:49 AM
joecautela's Avatar
Re: better strut?
I hear ya, the roads here are pretty rough and I'm trying to avoid too stiff a setup, so for the money I thought I'd try the sensatracs. I've had good experience w/ Monroe in the past. My last car I had I tried both Koni Reds and Yellows but had to run them on the softest setting to keep from breaking my teeth and the car. I also went back to rubber bushings versus the hard urethanes. That helped a lot too. Thanks!
Old May 8, 2007 | 03:05 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
Re: better strut?
I had some Monroes on my car before I got the Eibachs and the KONIs. Not a bad replacement part. They were alot better than the busted stockers. The Pro-Kit killed them in a hurry, though.
Ed1LE
Sep 30, 2018 09:14 AM
LT1Formula
Oct 8, 2015 08:34 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
tcflint
Sep 27, 2015 05:58 PM
