A few questions regarding the panhard bar!
Old May 17, 2007 | 03:55 PM
87y84's Avatar
Car: 1987 gta
Engine: 5.0L Aka 305
Transmission: Borgwarner 5 speed
Axle/Gears: 9 bolt 3.45
first off, let me introduce myself, new member to the community here @ 3rdgen. I own an 87 GTA with 5.0L M/T,(what a fun car!)
unfortunatly, a little tipsy, slick road, and a beefy muscle car don't mix too well! so long story short, as my car was going sideways it went over a curb, messed up the rim and bent the stock panhard bar. and prob. the lca's
In the process of fixing my car, i bought an adjustable panhard bar from EDELBROCK, the problem is that, it comes adjusted to o.e. specifics, and when i tried to install it it was about maybe 1" longer than the Mounting holes.(prob. from the sideways impact).
so my question is, can i just shorten the adjustable bar to make it fit, and then expand it once it is on? or do i have a different problem on my hands?
thanks!
Old May 17, 2007 | 04:26 PM
markymarco's Avatar
Car: 89 Camaro Convert,89 Camaro hardtop
Engine: 305 and a 357
Transmission: 700R4,T5
Axle/Gears: 4.10's and 3.43's
Re: A few questions regarding the panhard bar!
i dont think there would be a problem the adjustability is more so for a lowerd car so if you didint get the geometry right your rearend would be all out of wack
Old May 17, 2007 | 04:53 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
you can adjust it to make it fit and that wont hurt anything. the panhard bar is designed to center the rear in the car a keep it from moving sideways. install it at the length it needs to be, lower the car and see if the axle is centered in the car. if it is, you are set, if not adjust it. just check out the body mount for the panhard and make sure you didnt break/bend it.
Old May 17, 2007 | 06:49 PM
BMmonteSS's Avatar
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
A simple shove of the rear end will line it up, without a panhard bar installed the rear end is free to move side to side. My bet is that it has simply moved once you unbolted the stock bar.
Old May 19, 2007 | 01:02 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I'd just look carefully at the mounting areas. If it were me, i'd be inspecting everything under there for stress cracks or bending. Just to make sure I didn't tweak the car.
But yea, that's pretty normal, if you've got a plumb bob that can help you too. But measure the tire to wheel well area and get it centered on both ends and you're done.
Old May 19, 2007 | 04:51 PM
87y84's Avatar
Car: 1987 gta
thanks Errbody, gettin to it rite now!, one more Q. The stock LCAs', they seem like they have been compromised, what is the best replacement for 'em? any suggestions? reccomendations from personal use? i am looking for lcas' that are: reasonably priced, quality and ones that decrease the transfer of noise inside, or ones that have the least increase, i guess this has to do with bushings, thanks
Old May 19, 2007 | 08:42 PM
klause83z28's Avatar
Car: 83 z28
Engine: boat anchor 305 (ex CFI)
Axle/Gears: 3.23 10 bolt
Spohn makes them, along with UMI and BMR. From what I have been instructed, all of them are great companies and offer a reputable product.
cheers!!
Old May 27, 2007 | 02:50 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
Make your own LCAs. I did.
customblackbird
Aug 15, 2021 10:16 PM
deracer
Apr 11, 2016 12:04 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
ProtoMaster22
Aug 26, 2015 07:50 AM
redmaroz
Aug 16, 2015 11:40 PM
