LCA question(s)
Old Jun 18, 2007 | 08:24 PM
mild84's Avatar
Car: 1984 z28
Engine: 6.0
Transmission: glide
Axle/Gears: 3.50 9"
LCA question(s)
So I have a 1984 z28 that is drag race only. it has a 01 transam 10 bolt outback with a set of cheap adjustable summit shocks, and a spohn tq arm. that is as far as the suspension goes. It cuts real consistant 1.750-1.757 60' but I think it could do better. So I'm looking at getting a set of aftermarket lca's. Questions: 1. which brand is best? 2. will my car benifit from relocation brackets? Now the car is NOT lowered at all, and only on a 26" tire. I don't need a big lecture on how lca relocation brackets work, just a simple yes or no will sufice. thanks for the help.
Old Jun 21, 2007 | 08:28 AM
Shagwell's Avatar
Car: projects.......
Re: LCA question(s)
Aftermarket lca's eliminate the flex of factory arms. Relocate brackets give you a tuning aid to help traction. - That said, lakewood and UMI have poly ended lca's for around $100, and they're just as good as the rest. Relocates help 60ft even at factory ride height, although not being lowered you will probably be best in the first hole down.
Americanmouse
Sep 7, 2015 12:10 PM
zayne0
Aug 24, 2015 07:22 PM
Thirdgen89GTA
Aug 20, 2015 03:11 PM
redmaroz
Aug 16, 2015 11:40 PM
NBrehm
Aug 5, 2015 07:57 PM
