noisey front hub
Old Jun 24, 2007 | 09:44 AM
Radiorick's Avatar
Car: '89 t-bird SC/87 Z-28 vert
Transmission: auto
noisey front hub
I have this clicking noise coming from my front right hub area. I know it's not the brake, the brakes are in good shape. If I go real slow it starts clicking and it seems like the more I use it the louder it's gets. Any ideas? I'm possible thinking the bearings are bad. I do have 18" rims and 2" adaptors on the front, wonder if that has anything to do with it? Rick
Old Jun 24, 2007 | 11:06 AM
thepoz89's Avatar
Car: 89 Firebird 89 Formula one red one black
Engine: 350, 355
Re: noisey front hub
redo the front bearings with grease and while you are disassembling check to see if there are any foreign items near the hub/rotor. spin the rotor by hand to see if you can duplicate the noise. make sure rotor is not warped while turning it to rule that out as the culprit.
Old Jun 24, 2007 | 11:25 AM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
has work been done on it recently ?
is the cotter key for the spindle bearing nut hitting the dust cap ? or is the dust cap dented in badly ?
you will have to inspect yourself to figure out what it is, its probably something minor
customblackbird
Aug 15, 2021 10:16 PM
midge54
Dec 27, 2019 04:14 PM
deracer
Apr 11, 2016 12:04 AM
dyeager535
Aug 28, 2015 08:10 AM
1Aauto
Sponsored Vendors
Aug 26, 2015 02:18 PM
