Torque specs
Old Jul 4, 2007 | 01:00 AM
slackett1's Avatar
Car: 89 TransAm
Engine: 305TPI
Torque specs
Just finished a fuel pump replacement and want to make sure I've got everything bolted back as it should be.
Need torque numbers for:
-Lower shock bolts
-LCA's at the frame
-Sway bar mounts (inside each wheelwell)
-Torque arm bolts at the differential
-Panhard
Old Jul 11, 2007 | 03:42 PM
Shagwell's Avatar
Car: projects.......
Re: Torque specs
I've never seen anyone actually torque components like that to spec. I've seen them run up with impacts and with hand tools, but either way, just tight.
Old Jul 15, 2007 | 01:47 AM
slackett1's Avatar
Car: 89 TransAm
Engine: 305TPI
Re: Torque specs
Got it..
I tightened everything 'Ape' tight
Old Jul 15, 2007 | 10:14 AM
coolram62's Avatar
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
Re: Torque specs
If you haven't already found the torque values here is what I found;
Everything is in Ft/Lbs from the '82-'84 Haynes
Lower Shcok bolts - 70
LCA to Body - 68
Torque Arm Bolts at Differential - 100
Panhard bar - (Axle - 93),(Body bracket - 58)
Sway bar Mounts - (shaft to body bracket link bolt - 12),(Bracket to Body Screw - 35),(Over axle U-bolt - 20)
Hope this helps.
no green
Jan 9, 2016 09:22 PM
gord327
Oct 3, 2015 01:25 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
Navy8125
Exterior Parts Wanted
Oct 1, 2015 11:24 AM
