best bang for the buck?
Car: 1989 camaro rs
Engine: 305 tbi
Axle/Gears: 3.23 lsd swap
whats the best bang for the buck suspension mod for my 89 rs 305? there are alot of possibilities. i could get a strut tower brace, better pan hard arm, heavier sway bars, better trailing arms, wonderbar, ect. where is the best place to start for the money? what will provide the most noticeable difference in handling? what is the best order to do suspension work? where do you guys start and finish? so far suspension is stock, i fixed everything that was wrong with it, but stock. i replaced sway bar links, worn idler arm, and bad centerlink.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: best bang for the buck?
best place to start is subframe connectors
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Then perhaps springs, struts, and shocks.JamesC
Car: 1991 Pontiac ta 5.0l 2005 pontiac gxp 5.3l ls4 dod 2003 GMC Envoy 4.2l
Then replace the rubber mounts that are left after that trans torque arm sway bars etc. Anything your not going to replace with a upgrade anytime soon. What I mean by that is I replaced my rear panhard and control arm on the rear they came with new rubber so no need to replace the rubber on the old control arms. Hope that clears my statement up.
Damon
Sep 26, 2015 04:29 PM
