Need help removing wheel from Skulte spacer. (stud spins freely)
Old Jul 16, 2007 | 05:55 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
As I was swapping my street wheels with my race wheels today, one of the studs on my front spacer spun loose.
I think this was due to a messed up (or cross threaded) lug nut when I swapped my wheels last month.
Now, the lug is stuck on the stud and the stud spins freely in the spacer and I only have about 1/8th of an inch of clearance between the wheel and the spacer, so I need some ideas on how to get lug/stud off.
the wheels currently on the car are my 17x9.5 ZR1's.
thanks for any insight/advice you may have.
Old Jul 16, 2007 | 07:01 AM
1985WS6transam's Avatar
Car: 1988 Firebird Formula
Engine: 388 Carb
Axle/Gears: 4.10
Re: Need help removing wheel from Skulte spacer. (stud spins freely)
Any chance of getting a prybar behind the lug and pry at it while using an air gun to remove it?
Old Jul 16, 2007 | 10:45 AM
Zepher's Avatar
I've got a small pry bar, I'll give that a shot and see if it can work.
thanks
Old Jul 16, 2007 | 02:19 PM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
Good luck man... if that lug is truely crossed on the threads, its going to be fun removing. You might end up having to butcher the lug nut to get it off. I recently had to do this on a buddy's jeep. Ended up taking the dremel with a cutoff wheel and making slices until I could split it with a hammer and chiesel.
But...if its not on there too bad, pulling it tight with a pry bar is a good start.
Good luck!
Justin
Old Jul 17, 2007 | 09:49 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
You may try drilling out the stud with a cobalt bit until you drill out enough to cut the threads of the nut out too. This would probably be a last resort but probably a little safer for keeping the wheel nice and undamaged. Wont be an easy job any way you try it.
Old Jul 20, 2007 | 02:00 PM
Zepher's Avatar
This is the method that worked.
The pry bar and impact didn't work.
thanks again for the input.
Vintageracer
Jan 10, 2020 05:33 PM
Fronzizzle
Mar 18, 2019 08:29 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
BrianI
Aug 9, 2015 11:52 AM
3rdgenparts
Aug 8, 2015 07:09 PM
