what about spring clamps...
Old Jul 31, 2007 | 06:30 PM
suh_wheat_86305's Avatar
Car: 1986 Trans Am
Axle/Gears: 3.23 gears
I've seen, many years ago, a small clamp that pinched together a couple of coils. the clamps were simple and very cheap...
is this a viable option to cutting springs?
Old Aug 4, 2007 | 12:43 PM
Car: 1986 Trans Am
Re: what about spring clamps...
is there such distain for clamps that no one can bring themselves to comment?!
Old Aug 4, 2007 | 04:40 PM
No they are not a "viable" option. Never have been, never will be. Not any more "viable" than those little things you screwed in between coils to jack the car up.
Not that "cutting springs" is exactly what I'd call the "first choice", either. It's somewhere WAY behind just getting the right ones for what you want it to do.
Old Aug 4, 2007 | 05:49 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
in a word , yes . they are junk , and will ruin a somewhat decent spring . if you want to lower get a spring made for it , and a front end alignment .
Old Aug 4, 2007 | 09:12 PM
BMmonteSS's Avatar
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
There is nothing wrong with cutting springs, it's not like they just fall apart and make your car explode.
The right spring for the application can sometimes be made out of stock springs. The hard part is knowing what the right spring rate and height is right for a particular vehicle. That's where people get themselfs into trouble.
Old Aug 7, 2007 | 12:36 AM
Black89's Avatar
Car: Black 89 IROC
Engine: LB9
Transmission: Manual
Custom height springs are best, but I put 150K on a Cavalier that I lowered very successfully by about 2" with sets of "spring clamps". Never a problem, car aligned per specs and handling vastly improved. Installed clamps on each side of each coil, and resultant coil was noticeably stiffer. Project started out as a budget attack on newly installed gas-charged struts, which had raised car an inch.
Old Aug 7, 2007 | 12:41 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
I tried the clamps and they dont fit around our front springs, they are too thick and the coils are too close together for the clamps to fit in between.
LT1Formula
Oct 8, 2015 08:34 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
