1999 stock corvette wheels
Old Aug 13, 2007 | 07:53 PM
myvmax1's Avatar
Car: 91RS, 91RS
Engine: 305TBI, 3.1MP
Transmission: WCT5, TH700
Picked up a set of 1999 Corvette wheels. They are the factory 18x9 1/2 rear, and 17x8 1/2 front. The tire size is 275/40 rear, and 245/45 front. I know I'm going to need serious spacers. I dont know the exact offset of the wheels. I've been told I cant run spacers of 2-3 inches. But if I can, what size do I need, and where can I buy extended studs for a 91 RS disk/drum brake. Any help would be greatly appreciated. The wheels were DIRT cheap and I dont want to have to turn around and sell them.
Max
Old Aug 13, 2007 | 08:08 PM
DillonRager's Avatar
Re: 1999 stock corvette wheels
subscribing i want to know too.
Old Aug 13, 2007 | 08:12 PM
You need 2" on all 4. That's what I have on my car, same combo, fits perfect.
The "spacers" you need are really "adapters". They're a block of aluminum, that bolts to the stock studs; and they come with their own studs in them. You don't need longer lugs.
One of the guys that hangs out on this forum sells them. www.skulte.com Check there.
Old Aug 14, 2007 | 03:40 PM
myvmax1's Avatar
Car: 91RS, 91RS
Wow, only two inches? Not saying that your incorrect, but the fronts were looking more like three inches for the wheel just to clear the upper part of the strut mount (the top of the plate that bolts to the spindle). Two inches? They didnt offer these wheels with any optional back spacings did they? I cant imagine that they would, but you never know. $150 a pair is not TOO bad considering what they're made out of. But do you think I should go with 2.25 in? Just in case my car sits a tad lower or higher than yours? I'm just trying to get it right the first time is all. I know that rarely happens when you modify your car, but I'm trying. Thanks again for all the help. And any further information will be more than welcome.
Old Aug 14, 2007 | 07:16 PM
kubus_stroinski's Avatar
Car: 1991 Camaro RS
Axle/Gears: Tru-Track posi/Moser axles/4.10
you can run either 2 or 2.25 up front. i ran 2 up front at first and had no problems with your size wheel and then i did the c5 front brake swap which pushes it out another .25 inches. either way you're good.
Old Aug 14, 2007 | 08:32 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
2" on the front and LS1 rear out back with a 5/16" slip on spacer, so I would recommend buying 4 2.25" bolt on spacers.
Old Aug 15, 2007 | 02:23 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
I use 2" Skulte spacers and the Nitto Extreems are 285/35/18 in back and 275/40/17 in front. No Rubbing problems.......
Old Aug 17, 2007 | 06:16 PM
myvmax1's Avatar
Car: 91RS, 91RS
So 2.25in and I'm golden? Good deal. Thanks a million guys, informed input is allways welcome. By the way, those are some sharp rides. Very Clean Bird, and the hood on the black/green berlineta, Very sharp. Almost had one myself, think it was called a Daytona Turbo hood or somthing. Went conservative with a 2.50in functional cowl induction in the end though. Thanks again.
Max
Old Aug 17, 2007 | 06:40 PM
matt_p's Avatar
Car: 1991 Z28
Transmission: WC T5
Axle/Gears: 3.73 Posi
No. Get 2" I have those corvette wheel and its 2 inches.
If you plan to do brake upgrades the 2 inch pacers will leave you room, but with the 2.25 inch ones they might go out to far.
Old May 25, 2013 | 08:31 PM
87bigbirdy's Avatar
Car: 87 formula
would 2 inch spacers be sufficient fir an 87 formula?thanks
Old May 25, 2013 | 08:34 PM
87bigbirdy's Avatar
Car: 87 formula
sorry i meant to say thete c6 wheels..tire size woyld help as they are 18 in the front 19 in rear..is it really worth the for the looks cause i dont want to open up a can of worms with brakesor safety handeling..
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
kah992
Aug 19, 2015 02:55 PM
milk
Aug 10, 2015 06:26 PM
mustangman65_79
Aug 9, 2015 03:00 AM
