Question for the guys with drag only cars
Old Oct 2, 2007 | 07:46 AM
slownlowgmc's Avatar
Car: 83 camaro/98 gmc
Engine: 350/350
Transmission: 350/4l60
Axle/Gears: 4.10/3.42
I was wondering what everyone is using for the springs and shocks on the drag race only cars. I have been looking and still have not found any rear springs made for our cars. So post up what you got
Old Oct 2, 2007 | 05:50 PM
ross's Avatar
Car: 82 camaro
Engine: 434 ci
Transmission: t400
Axle/Gears: 9'' 4.10 gear
Re: Question for the guys with drag only cars
I have all stock 4cyl spring that came with my car with koni spa 1 drag struts up front and comp eng. shocks in the rear.
Old Oct 2, 2007 | 06:33 PM
Engine: 350/350
are you happy with the way everything works , would you change anything?
Old Oct 2, 2007 | 07:57 PM
1BADRZ28's Avatar
Car: 1982 Camaro
Engine: 555 BBC
Transmission: TSI Glide
Axle/Gears: Aluminum Moser 3.89
comp engineering 90/10 struts up front with stock coil spring. Qa1 Coilovers in the rear in stock shock location. The coilover adjustability is nice to have when visiting different tracks.
Old Oct 2, 2007 | 07:58 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
For years I was using V6 springs front and rear. Koni SPA1 front struts and rear shocks.
Last fall I did the back half on my car and now use a coil over system on the rear. Early this year I finally changed out the front springs to some trick springs. With my power level, the V6 springs just didn't give me the weight transfer I needed.
Old Oct 2, 2007 | 08:28 PM
ross's Avatar
Car: 82 camaro
Engine: 434 ci
Transmission: t400
Im happy as far as springs,struts and shocks go. Just wish I didnt use the south side lift bars non adjustable. My car has pulled a best 60 ft of 1.40 on a 28x10 drag slick.
Old Oct 9, 2007 | 07:22 PM
plumminfool's Avatar
Car: 1988 camaro sport
Engine: 355
Transmission: 5 speed
Axle/Gears: Ford 9 inch - 4.11 gears
Stock springs and struts up front and stock springs with air shocks on rear.
Old Oct 31, 2007 | 08:03 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
for years i ran the v6 springs, then i was informed that 4th gen convertible springs are a bit softer, so i swapped them out.
its worth a few hundreths 60ft in my application, and it rides a lil smoother.
Old Nov 1, 2007 | 09:43 AM
radialtireking's Avatar
Car: 85 Camaro
Engine: 437" small block
Transmission: glide
Axle/Gears: 3.70
Stock v6 springs with strage adjustable shocks in the rear. Car 60 foots consitantly in the high 1.20's on drag radials. I ran the stock v6 springs in the front with koni spa1 struts untill I went coil over in the front. I now run 14" long 175 pound springs. Car still sees plenty of street time and drives nice.
Old Nov 1, 2007 | 06:14 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
any pics of your ride?
sounds like a bad bitch!
Old Nov 2, 2007 | 07:32 AM
Car: 85 Camaro
Transmission: glide
Axle/Gears: 3.70
www.fquick.com/radialtireking
MustangBeater20
Oct 29, 2022 09:20 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
jharrison5
Aug 19, 2015 05:53 PM
86IROC112
Aug 17, 2015 02:00 PM
