all around good
Old Oct 27, 2007 | 05:09 PM
cajunnola's Avatar
Car: 1992 Camaro RS
Engine: 305 (for now)
Transmission: 5-speed
Axle/Gears: stock
all around good
I am starting to do some planning. I want to go through the suspension on my 92 rs and do some upgrades but I will drive the car to work some and just around in general. I live in Louisiana so lowering any is not wanted if I can keep from it. It will go to strip every now and then for fun and hit some curves from time to time. what does everyone think?
Old Oct 28, 2007 | 07:24 PM
cajunnola's Avatar
Car: 1992 Camaro RS
Axle/Gears: stock
Re: all around good
All right I ordered a wonderbar. The concencous from what I could read was that it was a must. Now from here I am sort of lost any advise? I have read yellow Koni's are the way to go but are they gonna ride bad? Are the just for racing or all around? I haven't seen or heard of a stock ride height upgrade spring. Do they not exist?Thanks
Old Oct 28, 2007 | 08:26 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: all around good
first of all check all steering components , ball joints , tie rods , idler arm , and so on . i rebuilt the entire front end on my 89rs [ all of the above ] , what a difference . then a S.T.B. , and a T.D.S. wonder bar . now one by one i am starting at the rear , changing all bushings to greasable poly ones . one step at a time , and still a day to day driver . with a driver [ like mine ] stock with good poly bushings are all you need to enjoy . i also live in the G.C. , so i know driving conditions . alignments of course are needed .
Old Oct 28, 2007 | 09:02 PM
cajunnola's Avatar
Car: 1992 Camaro RS
Axle/Gears: stock
Re: all around good
thanks uncle tom I was going to get the energy suspension bushing and trans mount. I think my rear springs are sagging some anyway becouse it sits low in the rear. I think I will go to parts wanted and try to get a good set of stock ones. what shock though? Mine are toast.
Old Oct 29, 2007 | 06:12 AM
Legal Disaster's Avatar
Car: 1986 Iroc-Z
Re: all around good
Go with Bilstein or Koni shocks/struts. I've run both and am impressed. As for stock height springs do a search on this forum for Moog springs, I'm not sure which ones are which but there is plenty of info here
Ghettobird52
Jul 5, 2024 11:18 PM
specialized
Jun 18, 2022 09:26 AM
Lmancha96
South Central Region
Oct 22, 2020 12:40 PM
MantyZ28
Jan 18, 2016 08:30 AM
ezobens
Aug 19, 2015 10:29 PM
