Is driving your camaro a constant arm battle with the steering wheel?
Old Nov 5, 2007 | 10:30 PM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
I have 245/50/16 tires and a completely rebuilt front end. Only thing not new is the rag joint and steering box. The car tracks pretty straight on the highway, but the moment the road gets the SLIGHTEST bit uneven its like a ghost is just jerking the wheel right out of my hand. Ruts...for example, it wants to go this way...it wants to go that way. I've never driven a car thats like this. I have to be careful because it will really jerk around at times, certainly enough to send me right off the road if I don't have a firm grip.
Any way to fix this? Anybody else's car like this?
Old Nov 5, 2007 | 10:41 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
Re: Is driving your camaro a constant arm battle with the steering wheel?
I have the same problem.
It's the wide tires.
Drive a vehicle with narrow tire and you'll see the difference.
Old Nov 5, 2007 | 11:14 PM
jimmy92rs's Avatar
Car: 1992 RS
Engine: 01' LS1
Axle/Gears: 10 bolt auburn pro posi, 4.10 gears
did u get the car aligned, its sounds like the caster my be off.
Old Nov 5, 2007 | 11:25 PM
a1990camarors's Avatar
Car: 1990 rs 1992 z28 1995 jeep
Engine: no engine, 383stroker, inline 6 4.0
Transmission: none, t5, auto
had the same probelm on a few camaros. one was ball joints and needed a alignment. one just needed a alignment. i wouldnt blame it on wide tires i have 9.5s on all 4 corners on my z28 and it handles just fine nice and tight
Old Nov 5, 2007 | 11:31 PM
jimmy92rs's Avatar
Car: 1992 RS
Engine: 01' LS1
look someone else agrees with meexcept u prolly had a camber problem
Old Nov 6, 2007 | 02:19 AM
Joez88Camaro's Avatar
Car: 1988 Camaro Sport Coupe Convertible
Engine: Your Momma
Transmission: I can go forwards and backwards
Shot ball joints can make this much worse, same with strut mounts that are pretty much on their way out. I thought I did a lot but it wasn't until I replace EVERY single little piece like the ball joints, control arm bushings, ragjoint, strut mounts, etc that you appreciate how well these old things can drive.
Old Nov 6, 2007 | 09:29 AM
BobItzaboy's Avatar
If the car is lowered and you are running high caster you are encontering bumpsteer. you will need to drop the tierods about 1" to correct the geometry and then get it realigned so they do not toe in on bumps.
Old Nov 6, 2007 | 11:36 AM
Ya if your car is lowered your probably having bumpsteer problems. Baer sells a bumpsteer kit for our cars wich ill be picking up before my RS goes down. I would also make sure nothing damaged in your steering wheel. ive seen some ppl fully rebuild there front end and still have horrible handling issues and it ended up bieng in there steering wheel.
Old Nov 9, 2007 | 07:53 PM
TheScaryOne's Avatar
Car: 1987 IROC-Z Camaro
Engine: L98 5.7L TPI
Transmission: 700-R4
Axle/Gears: 3.27 BW
You mean steering column, right? I'm having an issue there right now, I think it's causing binding, and it's driving me nuts.
Old Nov 9, 2007 | 08:25 PM
BobItzaboy's Avatar
Scary, when you get time, pull the top intermediate shaft bolt and separate the DD fitting so thesteering wheel can spin freely. You can inspect any bind in the column that way. I find it hard to believe the column is binding though. THe bearings would really have to be shot and I would think you would feel them grinding and wobbling.
Frozer!!!
Jan 19, 2024 04:55 PM
BlueIroc-Z
Jun 9, 2019 03:22 AM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
mustangman65_79
Aug 9, 2015 03:00 AM
johanlindgren
Wheels and Tires
Aug 6, 2015 03:32 PM
