Back in the Saddle
Old Nov 24, 2007 | 01:18 PM
megtom2's Avatar
Car: 1989 Pontiac Formula 350
Engine: 350 tpi
Transmission: 700
Back in the Saddle
OK, I posted this in the wrong forum. Sorry I am new here.
Ok, I owned a 1989 Formula 350 from 1991-99 until me wife wrecked it. With baby kids coming along no reason to go sports car again so I have done without for 8 years but have now bought another one.
My question is what is the first thing to do to tighten up the suspension? I was about to add a tower strut brace before my old one was wrecked. Good place to start or go ahead to the frame stuff? Does the lower brace really do a lot?
I ask this because the only thing I ever didn't care for was how loose that car felt but it seems that plenty of aftermarket stuff has come out now. Thanks.
Old Nov 25, 2007 | 01:50 AM
megtom2's Avatar
Engine: 350 tpi
Transmission: 700
Re: Back in the Saddle
No advice on where to start and what is needed. I mainly just want the car to be sturdier and tighter.
Old Nov 25, 2007 | 02:50 AM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
My 89 RS had the "wonder bar" and WS6 swaybars. It helps a ton over the RS bars. I would notice better if i had a shorter sidewall in the back but i set it up to hook in a straight line. With the shorter sidewayy tires it had no problem yanking you into another lane.
Old Nov 25, 2007 | 11:06 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Subframe connectors are pretty much the biggest difference. Drive without them, then install them - you'll think somebody swapped your car with a tube frame race car. It's very noticeable.
After that, look at poly bushed sway bars, and a strut tower brace in the front. That should make the thing corner like it's on rails.
Old Nov 27, 2007 | 04:20 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
Sub frame connectors and a wonder bar. Those will be your best bet. Then go to shocks, springs, sway bars.
Fronzizzle
Mar 18, 2019 08:29 PM
MORREALE5
Sep 13, 2015 09:16 PM
89gtaforsale
Aug 24, 2015 09:32 PM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
