Intrax Springs - which way is up?
Car: 91 Firebird Convertible
Engine: 305 TBI
I put in a set of springs and I noticed on the front set, the logo is upside down on the right (passenger side). I am 99.9999% SURE I put them in so it looked exactly like the spring that I pulled out. I only noticed the logo later.
Now I am second guessing myself. Anyone here running Intrax (purple) with flipped logos...
Re: Intrax Springs - which way is up?
im not familiar with the intrax personaly but did you index the springs right....put the end of the coil in between the two holes in the a arm? the end of the coil up top should be perfectly flat...the coil you should have indexed would have been round and just looked like a full coil was just cut off half way though the winde. do you remember what the spring looked like before it went in?
Engine: 305 TBI
I measured from the fender down and the drivers side is .5" higher. But the rear driver's side is also .5" higher
Engine: 305 TBI
LT1Formula
Oct 8, 2015 08:34 PM
